The main goal for this is I want a “virtual crossover” to save some space taking rack gear places.
I know that some people use aux fed subs, (eg assigning channels to Aux1, as well as main L/R outputs) then apply filters to Aux 1 to restrict the frequency.
but this suffers from the issue that when you turn down (or up) the main mix, you need to adjust a separate fader for this sub control.
By default the Main L and Main R are assigned to output 11/12, but they can be assigned to any/all outputs.
The issue is that it appears to be the processing is on the channel, not the output.
(so I want to assign Main L to out 1,2,3 and Main R to 4,5,6) then have different band-pass filters, time delays and output gain applied to each output, (not the Main LR.)
But the only way I can see to accomplish this is to use a short XLR to loop L/R back into a pair of desk channels (not routed to LR!) and then feed these channels to auxs with appropriate filters/time delays etc. then assign the aux channels to outputs the drive amplifiers.
Is there some other way that I haven’t thought of? - or do I need to just keep using an external crossover?
So, it looks as if you have a three way speaker system that you need a crossover for?
The loopback you describe is going to introduce D/A & A/D delays, making time alignment difficult, if not impossible. It’s also going to eat up a lot of inputs & outputs.
Look at feeding L&R to the 3 matrix outs (in stereo), and using the PEQ & delay they have to achieve a sort of crossover. You can then patch these to 6 output sockets. It may work for what you need, thought I’d go for a proper crossover / speaker processor unit.
not if the mix is post fader
that’s the way it works and that’s why it is a mixing desk not a PA processor
there are very cheap processors available, some with very small footprint like MiniDSP, Xilica Solaro QR or WorkPro AoIP Line devices
and there are more…
Choose a DSP that will take AES inputs to save a couple of conversion stages.
I use DBX Venue360’s, they met the processing and price points needed for my systems and
they will take AES inputs.
