Program to convert Asio(DANTE) to WDM
Hi guys,
I started my search yesterday.
I need a program which provides me the ASIO signal from Dante to the headphone jack of my notebook, that I can use Dante for PAFL.
I found a application called PureData https://puredata.info, which does the thing needed but with significant latency of 200ms and above.
Does somebody know a program doing this?
best regards Klemens
idr32
Editor only (3 times)
Korg nano
Dante soon
It’s called Core Audio on a mac, where aggregate audio devices have existed for 4+ years.
iDR-48, T-112, Mixpad
College
Thanks for the link.
I tested this yesterday with the DANTE card, but VAC cannot get the ASIO driver for the DANTE.
Probably I made a mistake during configuration, but from my point of view I need an app that can talk to two soundcards at the same time.
The signal path should be like this
iDR32 → DANTE → ethernet → ASIO driver (Dante) → ?? → laptop phones jack
idr32
Korg nano
Dante
quote:
...I need an app that can talk to two soundcards at the same time...
that’s exactly what the VAC audio repeater can do. UPDATE: nope not true, since VAC doesn’t work with ASIO drivers :frowning_face:
I’ll try this as soon as I have my Dante card annex Dante Virtual Sound card. Although I had very good results with all of my other sound cards, almost zero latency. One sound card in, other sound card out.
Wouter
PS And then I started using Splashtop to see if I could also get the sound from my laptop on my iPad, also with success but the only disadvantage was that it only worked using the internal sound card of the computer so in my case the quality was not so good.
Yes, I’ve thought about splashtop for PAFL - I’m going to give it a run on the iPhone when i get a chance, see how that sounds…
iDR32 mixrack
MixRack for iPad & Tweak for iPhone apps
Asus N61 Laptop (x2 wireless)
Sennheiser IEM (for PFL)
Dante card (soon!)
maybe this is what are you looking for:
https://www.klankwereld.com/matrik
PD is total different Software and will be mostly to do things whit OpenSoundControl (OSC)
Sorry on Mac ONLY not ASIO…
I need to do this as well.
I have downloaded PureData (PD).
It may do the job, but user friendliness is not its forte.
Hi Guys,
Tr
I tried this with windows 7 using the WDM driver and it works without using any 3rd party stream mixing app. I had already tried VAC before realising you can do it with native windows functions. In my setup, I have PAFL mapped to Dante 56/57 which is then mapped to 3/4 of the WDM driver. If you then go to windows mixer (speaker icon in your system tray)Recording Devices you should see DVS Receive 3-4. Then do a Properties and select the listen tab. you can then tick the “Listen to this device” and select the pull down option to be your PC speaker.
FYI, I did a lot of other trial and error testing with WDM options within win7 and found I can plug in a usb audio pre amp (m audio in my case) and found you can use similar techniques to add more inputs mapped to Dante (you can even use the internal PC mic)so you could use one of these for talkback.
Hope the is useful.
Cheers,
Mike
Maybe just one of these would solve the problem.
https://www.atterotech.com/products/dante-dio2x2/
Not sure on price yet. But it shouldnt be bad.
Gil Parente
Design & Integration
Entertainment Arts, Inc.
iLive 176, T112
iDR48 , iDR16, iDR10
Multiple iPads
Dante
Etc…
Hi Gil,
This looks interesting (also the 32 in/out model) if the price is right.
M.
Perhaps all are not aware that there is a new release of DVS out and it supports WDM natively.
This allows you to receive DANTE and route the signal to the windows audio mixer without any extra software or mucking around.
I used it on the weekend to send audio to a remote location via a wireless link (DVS has extra latency buffering compared to the brooklyn module) and it worked like a charm.
