Pulling shows from windows
Hi All
My usb port is broken, is possible to pull shows from usb stick via windows or tablet just until i get the spare parts for usb plug…
Cheers
@Belfast
To access shows from a USB drive using SQ-MixPad on Windows, set the AHSQ folder on the drive as your ‘Working Directory’ in ‘Utility’ when running SQ-MixPad Offline.
You will then see all shows on the drive, can recall them into SQ-MixPad offline, and subsequently ‘Push’ them to the console over a network connection.
(you can also ‘Pull’ a show back and store it to the drive if required)
Cheers!
