Today I used Q16 console with firmware v1.97 without router and without ipad. It worked fine then the touch screen froze. I turned off the console then turned it back on by doing a reset, the screen was still frozen. I plugged in a wifi router and used the app with iPad, the console responded correctly but the screen was still frozen. I reinstalled firmware v1.97, the screen remains frozen. What should I do?
Do the surface buttons still work?
Maybe try a full hard reset, back up any scenes before as it will completely wipe the mixer of all settings.
Press and hold the touch screen Reset and Setup keys together and then power up the mixer
Keep the keys pressed for at least 5 seconds while the mixer boots. Release the keys.
Check the Screen for damage or little pressure points. Use finger and wipe over the entire display. Maybe ther was a little pressure point. When you brush over the Display you must see the flicker of the liquids
