cfbird
8 November 2020 01:22
1
Subject pretty much sums it up.
I own a QU-16 and would like to use AES Out to a DSP/LMS with AES In.
I like Xilica for the money, and would like to mess with FIR.
For the Xilica XD-4080, the AES interface is described as follows:
“Transport 4x8 AES/EBU digital audio channels over a DB-25 connector
(Yamaha protocol)”
ref: https://xilica.com/wp-content/uploads/2017/09/XIL003_UserManual_XD.pdf
There are breakout cables that go from DB-25 to XLR.
QU-16 is AES3 with XLR style of pinout.
Can I connect to the Xilica from the QU without any intermediary devices?
I’ve read a bit about AES in general, but I do not understand the protocol much and am not certain if I am going in the right or wrong direction.
Thanks for your insight!
cfbird
8 November 2020 01:52
2
Also, the QU would be the master clock right?
mikec
8 November 2020 04:23
3
With my DBX DSP’s and using the AES input I set them to sync/clock to the primary
AES input.
The QU runs at 48k.
Hi CfBird,
The Protocol AES/EBU is a standard.
The DB-25 Yamaha or Tascam is a pinout Standard.
So you need a XLR<>DB-25 connector with Yamaha Pinout if you want to make it work.
If you have made the connection you have to set the Xilica to sync the word clock from the incoming AES/EBU signal
AES3 is a standard for the exchange of digital audio signals between professional audio devices. An AES3 signal can carry two channels of pulse-code-modulated digital audio over several transmission media including balanced lines, unbalanced lines, and optical fiber.
AES3 was jointly developed by the Audio Engineering Society (AES) and the European Broadcasting Union (EBU) and so is also known as AES/EBU. The standard was first published in 1985 and was revised in 1992 and 2003. AES3 has been ...
