Hi All, N00b here…
Have started sorting out how to use my QU-16 as an adjunct to Logic X (v 10.3.1) and getting it to work, bit by bit, the way i need. Have been experimenting in using faders via USB DAW Control to create automation in audio tracks (and, i guess other tracks, too.) The issue is, if i use a QU fader to create, say, volume automation, all seems fine, but when i look at the data, it seems to create very jagged data, and on replay there is a lot of judder on the fader during playback. Trying to see if there is a way to reduce/thin/smooth the data that is sent to the DAW, or, smooth the data once written to the track.
(Have appended a screenshot of a region which shows what SHOULD be smooth automation data for your delectation and delight!)
You can do this sort of thing in Final Cut, and Motion, but I can’t see a way of doing this with Logic. Anybody encountered this? Know of a solution, or workaround?
Any assistance, gratefully received!
Thanks in advance,
Timbo
