QU 16 channel stopped working
Hi, Channel 9 on my QU 16 is accepting signal which I can hear in my monitor mix as normal but output to LR has stopped. Nothing to FOH
I run a simple band mix which barely changes and (to my knowledge) I haven’t touched anything which might have caused this loss of output to LR
Any ideas or suggestions would be appreciated.
Robert
Is it (Ch9) still assigned to L+R. Can be relatively easy to change this by mistake - especially when using QuPad.
Press the “Assign” button on the desk & check that the select button of ch9 is lit.
Page 22 of manual
If there is signal to a mix then assign is easily the most likely culprit.
This is exactly what it was, thank you both for your help. Brilliant.
Thanks for reporting back :wink:
+1 :slight_smile:
nine times out of ten it was inadvertantly turned off on the iPad, not the console
Yes that is likely to be what has happened as I definitely didn’t mess with that screen on the console
