but how you can find the values in the lut? and how to get a 4 byte “CRC” from a byte function?
and which range in the file is included in this calculation?
Couldn’t an offline editor basically be something similar to the QU-Pad app that just stores all the settings to a file as midi commands, then when connected to the board, you just dump the file to the board? The board doesn’t care how the commands are received, whether live from an app or sequentially from a file.
that could be an option, but
you loose a portion of the haptic of the user interface.
I could accept it, if this software would run on a small
computer and you can transfer the scene setup via an extra
robust button (bluetooth, WLAN)
There are limitations to what settings can be changed with midi. The Qu-Pad app uses a custom protocol to transfer settings/control the mixer.
I thought qu-pad uses midi over ip. Even with limitations, couldn’t you use it to create different mixes when you don’t have access to the board and then during the gig, dump the settings between songs, bands, etc?
The Android app Mix Station is pretty complete. Make something similar that can save all its settings then can dump the settings to the board.
What would really be great is if you could play qu recorded multitracks through the app while you’re creating presets so you could get approximate levels.
You’ll never get multitracks over wifi. But the QuPad protocol could be used to dump complete state to the mixer…
Would be a really nice option to have…
Since you would be using the app offline, the multitrack files would be stored locally on your device and playing while setting up the presets. No WiFi involved until you go online.
Yeah, but the iPad would then have to emulate all the processing power of the Qu?
The hard part might be getting the multitrack recording to the device – iOS users would need camera connection kit (I don’t know anyone who owns this…) and there might be adapter hoops Android users must hop through in order to connect the USB drive with the recordings on it to their device, if the tablets even support external USB devices.
For a desktop editor, that would be much easier.
Just playing back the audio files without effects/processing at relative volume levels would probably be manageable, if you want accurate EQ, gating, and so on… things become more difficult (to implement) and increase processing power required.
For iOS and Android devices, transferring folders of audio files through the cloud would be easy enough, and desktops and laptops could use the usb drive directly.
And yes, just using the multitrack playback for setting levels would be all that’s needed since you can’t adjust effects parameters using midi anyway. Now if A&H decided to release the protocol their iOS apps use, well that would be a whole new ball game. Until then, an app that could store levels, mix settings, channel names, etc. to files then send them to the board as needed, I think would be helpful.
I still don’t get why you’d want to ‘play back’ multitrack - you can set preamps based on something that doesn’t pass through them…
Give me the ability to save a scene to the iPad, and maybe export/import to/from Dropbox/iCloud/gDrive/eMail/??? and that would be great…
I could see a situation where you record a rehearsal, then offline, while playing the tracks, you could set approx FOH and mix/monitor levels and other settings for each song, band, scene of a play, etc. There may even be times where you need to change settings during a song. Basically it would become almost an automation tool where you can queue up your settings files and send them to the board at each change. You can do all this now using saved scenes, but the point of the offline editor is you wouldn’t need access to the board while creating the presets and someone could be making any needed changes to the files during the gig, on-the-fly, before they’re needed. You can’t do that while using the board.
Again, all of this would be subject to the limitations of the QU’s MIDI over TCP/IP unless A&H opened up their iOS API.
+1 Editor the QU
+1 !
“How could you make Qu even better, you ask?” … Offline editor please!
Pretty Please!?!
By A&H’s thunderous silence, and their apparent unwillingness to part with the CRC algorithm that is needed by one who has the rest of an editor figured out, I’d guess the answer is nah. The QU is what the QU is - and it will never have an off-line editor, much to my chagrin. Really, how old is the platform now? I’m not saying they’re not busy, but there has been opportunity after opportunity that have passed.
(sigh)
def calcCheckSum (scenearray):
“retuns the CheckSum of a Scene filedata array”
lut = [0x00000000,0x77073096,0xEE0E612C,0x990951BA,0x076DC419,0x706AF48F,0xE963A535,0x9E6495A3,0x0EDB8832,0x79DCB8A4,0xE0D5E91E,0x97D2D988,0x09B64C2B,0x7EB17CBD,0xE7B82D07,0x90BF1D91,0x1DB71064,0x6AB020F2,0xF3B97148,0x84BE41DE,0x1ADAD47D,0x6DDDE4EB,0xF4D4B551,0x83D385C7,0x136C9856,0x646BA8C0,0xFD62F97A,0x8A65C9EC,0x14015C4F,0x63066CD9,0xFA0F3D63,0x8D080DF5,0x3B6E20C8,0x4C69105E,0xD56041E4,0xA2677172,0x3C03E4D1,0x4B04D447,0xD20D85FD,0xA50AB56B,0x35B5A8FA,0x42B2986C,0xDBBBC9D6,0xACBCF940,0x32D86CE3,0x45DF5C75,0xDCD60DCF,0xABD13D59,0x26D930AC,0x51DE003A,0xC8D75180,0xBFD06116,0x21B4F4B5,0x56B3C423,0xCFBA9599,0xB8BDA50F,0x2802B89E,0x5F058808,0xC60CD9B2,0xB10BE924,0x2F6F7C87,0x58684C11,0xC1611DAB,0xB6662D3D,0x76DC4190,0x01DB7106,0x98D220BC,0xEFD5102A,0x71B18589,0x06B6B51F,0x9FBFE4A5,0xE8B8D433,0x7807C9A2,0x0F00F934,0x9609A88E,0xE10E9818,0x7F6A0DBB,0x086D3D2D,0x91646C97,0xE6635C01,0x6B6B51F4,0x1C6C6162,0x856530D8,0xF262004E,0x6C0695ED,0x1B01A57B,0x8208F4C1,0xF50FC457,0x65B0D9C6,0x12B7E950,0x8BBEB8EA,0xFCB9887C,0x62DD1DDF,0x15DA2D49,0x8CD37CF3,0xFBD44C65,0x4DB26158,0x3AB551CE,0xA3BC0074,0xD4BB30E2,0x4ADFA541,0x3DD895D7,0xA4D1C46D,0xD3D6F4FB,0x4369E96A,0x346ED9FC,0xAD678846,0xDA60B8D0,0x44042D73,0x33031DE5,0xAA0A4C5F,0xDD0D7CC9,0x5005713C,0x270241AA,0xBE0B1010,0xC90C2086,0x5768B525,0x206F85B3,0xB966D409,0xCE61E49F,0x5EDEF90E,0x29D9C998,0xB0D09822,0xC7D7A8B4,0x59B33D17,0x2EB40D81,0xB7BD5C3B,0xC0BA6CAD,0xEDB88320,0x9ABFB3B6,0x03B6E20C,0x74B1D29A,0xEAD54739,0x9DD277AF,0x04DB2615,0x73DC1683,0xE3630B12,0x94643B84,0x0D6D6A3E,0x7A6A5AA8,0xE40ECF0B,0x9309FF9D,0x0A00AE27,0x7D079EB1,0xF00F9344,0x8708A3D2,0x1E01F268,0x6906C2FE,0xF762575D,0x806567CB,0x196C3671,0x6E6B06E7,0xFED41B76,0x89D32BE0,0x10DA7A5A,0x67DD4ACC,0xF9B9DF6F,0x8EBEEFF9,0x17B7BE43,0x60B08ED5,0xD6D6A3E8,0xA1D1937E,0x38D8C2C4,0x4FDFF252,0xD1BB67F1,0xA6BC5767,0x3FB506DD,0x48B2364B,0xD80D2BDA,0xAF0A1B4C,0x36034AF6,0x41047A60,0xDF60EFC3,0xA867DF55,0x316E8EEF,0x4669BE79,0xCB61B38C,0xBC66831A,0x256FD2A0,0x5268E236,0xCC0C7795,0xBB0B4703,0x220216B9,0x5505262F,0xC5BA3BBE,0xB2BD0B28,0x2BB45A92,0x5CB36A04,0xC2D7FFA7,0xB5D0CF31,0x2CD99E8B,0x5BDEAE1D,0x9B64C2B0,0xEC63F226,0x756AA39C,0x026D930A,0x9C0906A9,0xEB0E363F,0x72076785,0x05005713,0x95BF4A82,0xE2B87A14,0x7BB12BAE,0x0CB61B38,0x92D28E9B,0xE5D5BE0D,0x7CDCEFB7,0x0BDBDF21,0x86D3D2D4,0xF1D4E242,0x68DDB3F8,0x1FDA836E,0x81BE16CD,0xF6B9265B,0x6FB077E1,0x18B74777,0x88085AE6,0xFF0F6A70,0x66063BCA,0x11010B5C,0x8F659EFF,0xF862AE69,0x616BFFD3,0x166CCF45,0xA00AE278,0xD70DD2EE,0x4E048354,0x3903B3C2,0xA7672661,0xD06016F7,0x4969474D,0x3E6E77DB,0xAED16A4A,0xD9D65ADC,0x40DF0B66,0x37D83BF0,0xA9BCAE53,0xDEBB9EC5,0x47B2CF7F,0x30B5FFE9,0xBDBDF21C,0xCABAC28A,0x53B39330,0x24B4A3A6,0xBAD03605,0xCDD70693,0x54DE5729,0x23D967BF,0xB3667A2E,0xC4614AB8,0x5D681B02,0x2A6F2B94,0xB40BBE37,0xC30C8EA1,0x5A05DF1B,0x2D02EF8D]
checksum = 0x0
idx = 0x0
for i in range (0xC, 0x651C):
idx = ~(scenearray[i] ^ checksum) & 0xFF
checksum = lut[idx] ^ 0xFF000000
return checksum
CRC has been known for at least 10 months. And “findable” for a while now if you look around.
Also, documentation on most of the file contents:
There’s also at least one person who has used it in some python scripts: GitHub - antonmeyer/AH_DAT_Files (seems to be the implementation of the crc calculation that dtrt posted).
So @fxk, all of the information is out there – and my 10 month estimate was off, 21 months is more accurate. The big road-block is putting in the large amount of time required to make an offline editor.
Mea clupa! I missed the point in the thread where the CRC had been unraveled.
Please put my comments in the file “rambling of idiots”.
