Hey all
I’m looking for a permanent flight case for my QU-16 and I’m really struggling.
I need to be able to keep 4 x IEMs and my router in the case too (All permanently connected up if possible)
I thought this might work
But the QU-16 states a minimum of 11u and the above is only 10
Any help?
Thanks in advance.
The SKB Gig-rig is 14U on top, 6U down the front. I used that with my mixwizard and GEQs. However it’s by design not the most compact rack I’ve seen. You won’t get it into a car.
Way too big for my needs. Although I do have a Transit Connect van, I doubt it would fit in it with all the rest of the gear I take.
Slightly smaller:
In fact, I’ve got one that’s not in use at the moment, I could probably be persuaded to sell it…
Slightly smaller:
In fact, I’ve got one that’s not in use at the moment, I could probably be persuaded to sell it…….
That looks about right doesn’t it. What might you be looking for it?
What do you use if not this yourself?
I’ve now gone for a wheeled rack with about 18U underneath.
It contains, CD player, 4 radio receivers & a drawer for the microphones, patch panel and small mains distro and a drawer I can lock the iPad in.
I’d sell the case at 1/2 that new price I guess + the postage unless you are close enough to meet up (Near Chichester). I have removed the “hinge” type catch from the lid, as one of the places I used to use it was under a little balcony and too low to get this lid off. No the lid can slide off, rather than needing to be flipped up and over.So, theoretically, it’s not quite as strong I guess, but it still worked for me with 4 catches still in place.
Cheers man, so do you reckon I’ll get 4 x IEMS and my wifi router
https://www.argos.co.uk/static/Product/partNumber/1397138.htm#pdpFullProductInformation
in there below permanently too, with all the cables always attached in the rear monitor mixes, power lead, cat5 network cable etc?
Any ideas what postage might be?
www.parcelmonkey.co.uk are usually the cheapest around.
Cheers
