Qu-16 USB LR Streaming Help
So I work within internet broadcasting. I’ve been using a behringer x2442USB this mixer was able to send the main output via usb to the computer and I am looking to do the same. So that my Master LR on the QU-16 is sending everything in a single stream that I can use a program like Xsplit or OBS to pick it up and then send it out via the online broadcast.
I can’t seem to get the routing right, help is greatly appreciated.
USB output routing in the manual.
What OS on he PC, Redmond might want L&R sent as USB channels 1&2?
Setup > Output Patch > USB Audio
By default 17-18 in the DAW will be assigned to record LR on a Qu-16, using the above you can freely assign what is sent to any of the DAW or Qu-Drive record channels.
