Hi all,
FYI I tend to type a bit so feel free to skip down to a TLDR, thanks.
I’m new here and fairly new to the Qu, though I had a Zed prior so I’ve long liked AH products. Definitely has been a steep learning curve switching to such a far more capable digital mixer, but I’m getting the hang of it and able to fulfill a lot of functions that were difficult or impossible on the Zed.
One strange thing has popped up and I haven’t seen a solution through searching, though searches here did help me with my initial questions when it came to the USB stereo mixdown / main out (which shows as “Line (Qu-16)” under inputs to PC), as I originally didn’t quite get why I could multitrack in a DAW but not get a simple mix in Audacity.
So I learned to turn channel 1 and 2 under the USB send panel to LR L / LR R and I can record a stereo mixdown fine in audacity. I have to change this it I want to multitrack in Pro Tools or something but that’s fine.
Strangely, this doesn’t work for OBS Studio though. It recognizes the input - the Line (Qu-16) - but the signal is really weak. It’s only OBS as I can do the same in Audacity or a DAW (if I set it up to just record two, L/R tracks), and haven’t experienced the issue elsewhere.
I did have some of the USB noise issues like described in the pinned thread that’s a known issue, but switching to a real sturdy USB cable seemed to solve that for me. I’ve also hooked up to two desktops and a laptop. all PCs, so it doesn’t seem computer specific. I currently just have a Mogami XLR L/R to 1/8” TRS as a front line input to the PC for OBS, but it seems silly that I wouldn’t be able to use USB.
TL;DR::: With channels 1/2 on USB sends set to LR L and LR R, and mixing on the main LR mix, I get an extremely weak / almost inaudible (or completely inaudible) signal on my USB mixdown line in while using OBS Studio. The USB line itself is fine as I can stereo mixdown record in Audacity or a DAW or multitrack just fine, but OBS has issues. Currently it’s forcing me to connect the main out to an 1/8” input, which isn’t ideal.
May be as simple as OBS looks for different channels, but I’ve been stumped, any help is much appreciated.
