QU16 works fine with a stand-alone wireless router, but when I plug into our LAN with DHCP engaged, it will not pull an IP. router and cable are fine. Router is also feeding an iMac which is pulling an IP just fine. Anyone else have a similar issue?
I know it’s obvious, but is DHCP enabled on your Qu?
UPDATE: I can connect if I manually assign the ip address, but the console will not show up on the app. I have to connect the app manually with IP address.
Yes, but nothing happens…to test that, I turned off DHCP, set all addresses to 0.0.0.0 and applied. I then re-engaged DHCP, but the numbers grayed out and stayed 0.0.0.0.
Another obvious question. Is your router set as a DHCP server? Could it be your iMac is set for manual IP address acquisition?
Try restarting router with QU already connected via ethernet? I always have QU running before router starts.
I suspect most folks don’t want to be connected to a LAN.
Same here - I have it connected via ethernet - lights on Hub are flashing. There are 25 other devices connected as well, most of them over wifi. So, DHCP is working.
It is not recommended to run the mixing desk as a dhcp client…
use fixed adresses instead
but if you set it to dhcp it needs to restart to take effect
since there is no other way to restart the network stack inside
I had same issue. Finally found the assigned IP address under Utilites tab and then under the Diagnostics tab on mixer. Wish that had been in the manually. Would have saved a lot of hours troubleshooting.
