QU 24 and D-snake
Hello,
I am completely new to digital mixing.
I am interested in getting a QU24 Mixer.
I just wanted to ask please that if I use the QU24 mixer front of house with an AR2412 on stage and then use the dSnake to connect to the front of house position, can the engineer front of house still use the input sockets on the back of the mixer at the same time as the D-snake. We have all live instruments on stage but then we also perform to a click track run from either a laptop or a Tascam Solid State player which needs to be set up and operated from the front of house mix position, so once the dSnake is connected do the inputs on the back of the mixer stop working ?
Many thanks.
Yes. It’s either or. You have choice of input 1-24 local or 1-24 DSnake. Just obviously not both at the same time.
There is a routing or patching screen for this. Press select on any channel. Press the preamp section in the processing screen and then the function button lower left side of the touchscreen. There you find the input patching. Local or Dsnake or USB.
If it wasn’t clear enough, the choice is per channel! And in addition to the 24 mono channels on a Qu24 there are also three stereo input channels (ST1-3), which could be sourced via dSnake or locally as well (or from USB).
Was gonna mention those and forgot.
Many thanks for that guys.
Hi Andreas,
If the choice is per channel, does that mean that I cound have 20 channels set to dsnake and 4 set to local at the same time.
Thanks again.
Yes, any combination of local/USB/dSnake.
The usb is globally selected between QuDrive and usbB
Thanks Bob.
