QU 24 & Reaper no input signal
Hello,
I recently purchased a qu-24 and have some difficulty getting it to work with Reaper on a MacBook. A few things first:
  • I have the latest firmware installed on the qu-24 (1.95)
  • I have the latest DAW control driver installed on the Macbook (1.6)
  • DAW Control is configured and seems to be working fine (except I can’t seem to map the Reaper master fader to the qu-24 master)
  • I have also confirmed that under “Audio Device Settings” in Reaper I can see the Audio Device is set to “QU-24 Audio”
What is not working is I cannot seem to get an input audio signal into Reaper. I have armed track 1 in Reaper which corresponds to channel 1 on the qu24. I can see a signal (kick drum mic) on the qu-24 and have adjusted the gain under “Processing”.
Also, when pressing “function” within the “processing” screen I have the global USB source set to USB B Streaming and channel 1 is set to “local”
What am I missing? Is this a Reaper issue? Any help would be greatly appreciated.
Some progress made. I left out that I use Mojave on my MacBook. Turns out with Mojave you have to go into “Preferences->Security and Privacy” and under Microphone you have to select Reaper. After I did that I was able to send audio from QU24 into Reaper and record. My new issue is getting the USB streaming audio back to the QU-24. I have tried setting all channels to USB when pressing “function” within the “processing” screen. No sound yet. I’ll keep digging but if there is something obvious I am not doing please let me know. I am new to the QU as well as DAWs
