QU 24 to AR2412 Expander
Has anyone used the AR2412 Expander with a QU Board? Im setting up a church and wondering if you can dedicate 2 of the outs on the AR2412 to be the Mains L/R for the QU24 board? So that you only need to run CAT5 cable from the board to the stage where the inputs will be… (or do you need to run XLR Mains from the board to the stage in addition to the CAT5?..). Hopefully this makes sense… thanks.
You can assign any of the busses to any of the outputs. It doesn’t matter if the outputs are physically located on the console itself or on a connected stage box. So yes, if you want to send the Main L/R output to some of the stage box’s analog outputs, that is no problem and very easy to do.
I figured and hoped that was the case. Thx!
