Qu-24 with Road Case (Local MA Sale)
Allen & Heath Qu-24 Mixer with Road Case
Local sale outside of Boston, MA
24-channel Digital Console with 25 Motorized Faders, Total Recall, Parametric EQ, Touchscreen Control, 5 Cores of ARM DSP Processing, 4 Onboard FX Engines, and Integrated Multitrack USB Recorder.
In excellent condition, only used for a handful of shows, always kept in the road case (included in the sale).
P-Touch labels by the Soft Keys can easily be removed (have them there for quick access at-a-glance).
Only selling because I use my Qu-16 for the majority of my shows and this is not getting used enough to justify keeping it.
I can deliver to any location within an hour of Boston or you can demo it here.
$2000
Allen & Heath Qu-24 Digital Console Features:
    :black_small_square:    24 AnalogiQ total-recall preamps integrated with DSP for optimum transparency and gain accuracy
    :black_small_square:    Ergonomic layout and workflow is comfortable, fluid, and intuitive
    :black_small_square:    Color touchscreen and dedicated data encoder give you quick and easy access to all settings
    :black_small_square:    Key processing tools are presented clearly on the SuperStrip, with 1 function per physical control
    :black_small_square:    25 automated, motorized ALPS faders (24 arranged over 2 layers) speed up and enhance your mixing
    :black_small_square:    4 groups give you subgrouping flexibility to LR for level masters and/or processing
    :black_small_square:    Total recall lets you save and recall scenes (snapshots) at the press of a button
    :black_small_square:    Onboard studio-grade dynamics and FX algorithms derived A&H’s iLive pro touring series
    :black_small_square:    Built-in interface streams multitrack audio to/from your Mac (OSX class-compliant)
    :black_small_square:    Plug-and-play with any DAW supporting Core Audio, including Logic, Cubase, Reaper, and Pro Tools
    :black_small_square:    Qu-Drive delivers 18 channels of 24-bit/48kHz recording/playback to/from your USB hard drive
    :black_small_square:    5 dedicated cores of high efficiency ARM processing provide state-of-the-art processing
    :black_small_square:    Optional Qu-Pad app frees you to tweak monitors and PA from your iPad, onstage or around the venue
    :black_small_square:    Fully compatible with A&H’s ME Personal Mixing System
    :black_small_square:    dSNAKE port lets you connect to a remote AR2412, AB168, or AR84 Stagebox via Cat 5e digital snake
    :black_small_square:    Matrix adds 2 further stereo outputs equipped with full processing to the console’s extensive I/O
    :black_small_square:    18-gauge, cold-rolled Zintec steel frame delivers strength, rigidity, and distinctive looks
More images here:
Also includes a soft vinyl dust cover with cable flap made by Digital Deck Savers.
SOLD
