QU-32 DCA Group Question
Hi folks,
I am using my QU-32 in a slightly unconventional way as my mixing desk linked up to Cubase for making recordings at home, rather than in a live situation. However, I think my question is probably applicable to both home recording and live situations.
I have my mix split into 4 DCA groups, Core, Rhythm, Vocals and FX. I notice that if I PAFL the Rhythm DCA group, the sum of the channels in it is consistently reaching at +6db with peaks at +12db. However my L/R PAFL is peaks around +3db.
Is there a problem with my mix such that I need to reduce the levels going into the DCA for the Rhythm DCA group to prevent some kind of inherent audio problem in the mix?
Thanks.
There is no audio signal on a DCA, the PFL is the pre fade sum of all the channels assigned to that DCA so it will be higher.
Hi Mike thanks for clarifying!
