QU-32 Mini ST3 Jack broken
I have a QU-32 and the 1/8” TRS Jack for ST3 broke loose - so aside from undoing the thousands of screws and all the faders and knobs - is there a way to fix this?
I tried super glue which didn’t work (I know..don’t say anything).
The 1/8 TRS jack is on a small circuit board with the USB jack, you may be able to get to it by removing the side end cap taking out all the screws out all around the edge and sliding the end cap out.
I had a QU Pac opened up to change the screen and notice that board.
Have you done that type of repair work before?
I’m holding back on my super glue comments!!!
I had a similar issue with my QU-16 (somebody stumbled over a cable and the jack input broke) It is not that hard to open the mixer and replace he small print that carries the jack. I bought it at an A&H service center for €43,-
The partno is ALLENH.004-392X, PCB Assy QU-16 H’phone+USB
Oh, and extra info : you only have to remove the screws on the bottom and then you can slide the bottom lid off. No need to remove the faders and knobs.
Good to Know. And thanks for the part number.
No I haven’t done that kind of work - but I’m not worried - things are pretty self explanatory so I think I can get it.
BTW That Part Number is something else -
