Qu-5 SMR Reverb Stops and Restarts When Changing Scenes
I’m having an issue where the SMR reverb stops and restarts when changing scenes while using an FX send. The delay works fine and hangs over through the scene change, but the reverb cuts out briefly and builds back up.
Troubleshooting so far:
  • Blocked all FX parameters in Global Recall Filters.
  • Safed FX sends and returns.
  • Tested switching between two identical scenes.
  • Disabled Main LR compression.
  • Confirmed FX send/return faders don’t change.
Nothing has resolved the issue. I’m only trying to recall instrument fader levels without interrupting the reverb.
Has anyone experienced this or found a solution?
Maybe someone from AH can chime in.
Here’s an example at 1:58:00 - 1:58:06 you can hear the reverb dip with the scene change https://www.youtube.com/live/a18RBe1alpA?si=-mioiXJOWFadH3de&t=7080
Is anyone at Allen and Heath active in this forum?
I’ve not noticed the same reverb cutoff with changing scenes you’re experiencing. I’ll have to try the reverb added in again, as I’ve gotten my FX minimized within the last few weeks. I’m using instead my delay and reverb from Studio One’s DAW being inserted in the Livestream mix.
I’m using a Qu-5 with the 1.2 update.
We are! But, if you’ve got a support request rather than a general discussion point, it’s best to get in contact with us directly so we can help you.
support@allen-heath.com or https://support.allen-heath.com/hc/en-gb/requests/new
