QU-5D Dante clock issues
QU-5D – Repeated Dante Clock Loss and Audio Dropouts
Our client’s QU-5D is intermittently losing Dante synchronization, resulting in random audio dropouts.
The QU-5D is configured as a Dante clock slave (Clock Source = Dante).
In two different system configurations recently, the QU-5D lost Dante clock synchronization. Dante Controller reported that the QU-5D had lost sync and subsequently lost its Dante flows. We heard an audible click, followed by a complete loss of audio.
CASE 1 – Live Concert / Broadcast Recording
The QU-5D was used in a live concert setup as the broadcast console, mixing the live audio for video recording.
System configuration
  • FOH: A&E dLive
  • Monitors: Yamaha DM7
  • Broadcast: Allen & Heath QU-5D
  • QU-5D receives its Dante flows from the dLive
  • Dante Primary and Secondary networks were both operational
  • Dante Clock Leader: dLive
  • Professional Yamaha network switches throughout the system
  • Dante network was fully configured
First show
The system operated perfectly for the entire day.
Second night
The QU-5D suddenly:
  1. Lost Dante synchronization
  2. Lost its Dante flows
  3. Produced audible clicks
  4. Eventually lost audio completely
Troubleshooting performed immediately
The audio engineer:
  1. Removed all Dante flows from the dLive in Dante Controller and re-established them — no improvement
  2. Rebooted the QU-5D Dante card from Dante Controller — no improvement
  3. Changed the dLive → QU-5D Dante flows from unicast to multicast
After changing the flows to multicast, the system started working again.
Unfortunately, we had already recorded approximately 20 minutes of video without audio.
CASE 2 – Post-Production Studio
The same QU-5D is also used in a post-production studio.
Again, the QU-5D is configured as a Dante clock slave.
The main audio system is based around:
  • DAD Core 256 – audio interface / routing hub
  • Prism Sound ADA-128 – audio converter
  • Clock Leader: Prism Sound ADA-128
    We also tested the DAD Core 256 as the clock leader.
The DAD Core 256 and ADA-128 are connected to a Linksys DGS-1210-28 switch, configured for Dante.
The system also has a direct secondary redundant network connection between the relevant devices.
The QU-5D is connected to the Primary Dante network via the DGS-1210-28.
Problem
We are experiencing essentially the same problem as in the live-show configuration:
  • QU-5D loses Dante synchronization
  • Dante Controller reports loss of sync / Dante flows
  • Audio clicks
  • Audio subsequently drops out completely
This is particularly concerning because the problem occurs in two completely different environments, with different Dante devices, different clock leaders, and different system configurations.
Important point regarding the clock configuration
We have not yet tested the QU-5D as the Dante clock leader.
In our real-world applications, however, the QU-5D will normally be used as a broadcast/recording console, receiving audio from the main Dante system. Therefore, it is expected to operate as a Dante clock slave, rather than as the clock leader.
For this reason, testing it only as a clock leader would not really reproduce our intended use case.
Our questions
Given that the same QU-5D exhibits essentially the same Dante synchronization/audio dropout problem in two completely different systems, could this indicate a fault or instability in the QU-5D Dante interface/card?
Or are there other Dante configuration or troubleshooting steps that the community would recommend before concluding that the Dante card is defective?
In particular, we would appreciate advice on:
  • Dante clock stability when the QU-5D is operating as a slave
  • Possible issues with the QU-5D Dante card losing the Dante clock
  • Unicast vs. multicast Dante flows
  • Dante Primary/Secondary redundancy
  • Switch configuration / IGMP / QoS considerations
  • Whether there are known issues with the QU-5D Dante implementation
  • Any recommended firmware or Dante firmware checks
  • Any diagnostic procedure that could definitively determine whether the QU-5D Dante card is faulty
The fact that changing the dLive → QU-5D flows to multicast immediately restored operation in Case 1 is particularly interesting, although we are not sure whether this is related to the underlying problem or simply happened to restore the flows.
At this point, we would like to determine whether we are dealing with:
1. A network/Dante configuration issue,
2. A clocking issue, or
3. A hardware/firmware fault in the QU-5D Dante card.
Any recommendations for further testing would be greatly appreciated.
@SowattMusic (great handle btw!)
Thanks for the detailed and neatly formatted report, and also for getting in touch with us directly via support.allen-heath.com
One of the team will get back to you there and help figure out what’s going on.
As a general point for others who may come across this thread however, it is often recommended to let the Dante network choose it’s own clock leader, and then clock all other devices to the Dante network. So I would start with that configuration and no switches before adding other elements one by one.
While I don’t think there is a single right or wrong answer here - given that you want the same audio to go to several different places, I think multicast is going to perform better (ie use less resources) than using unicast. It could be the network eventually got overwhelmed with the multiple instances of unicast data where sending out a single set of multicast data could be less likely to overwhelm the network. But ultimately I am just taking an educated guess here…
Did you end up reaching out to Allen and Heath and getting a reply.
I’ve been running into the same issue when incorporating into my larger dante setup but works fine when run on an isolated with I/O devices. I have confirmed all config settings are correct for the device to become a clock slave, and the rest of the dante devices on my network aren’t having any problems the mixer just drops out and disappears from Dante controller.
Also happens to the brand-new unit we’ve received in the last week (fresh out of the box haven’t pushed any updates but confirmed it’s running on the most recent firmware) that was to be installed in a 24/7 venue.
This makes me mildly nervous. I just had my QU-5D out for its first event with Dante on a wider network (not just my own private network) and had issues with the Dante dropping out, regardless of who was clock leader. I had the QU, two Shure MXWANI8, and an Avio 2 output and all four devices would periodically present issues in Dante Controller. All unicast flows from the QU to the various devices to send an audio feed around a building.
Now I’m hoping this was just network latency issues, since I was seeing some spikes on occasion…but reading about possible issues with the QU itself does make me nervous.
Hello,
Yes, I have contacted them. I ran all kinds of tests with support, and it definitely looks like the Dante card has an issue. The Dante clock unlocks every 3 hours, while no other equipment loses sync at all. I tested it in different configurations and equipment setups.
Conclusion: the Qu-5D is defective as far as its Dante card is concerned. I am sending it back very soon.
It might well be a bigger problem with their Dante card on the QU-5D which is different from their other cards (no redundancy, lower channel count).
It is indeed scary: it failed in a a very important live show for me. The show is lost, the client is not happy.
All tests conclude that it is an random every few hours Dante crash on the QU-5D side.
It does nor affect any other equipment on the network.
To Brian: No multicast was not enabled at all here.
it is another problem
Cheers
My suggestion was to turn ON multicast.
Unicast creates a single “point to point” data flow. You are sending the audio from the FOH console going to multiple destinations (broadcast and monitor desk). Because you have chosen to use Unicast, in order to send audio to both the broadcast and monitor desk the Dante system has to duplicate the unicast Dante data stream. It then sends one unique unicast data stream to each destination. (Edit - due to the number of Dante devices on the system, it might even be more than two identical data streams. I don’t know exactly how you are routing audio currently, but by using Unicast you are sending out a unique set of data to every device on the network - even if that data is having to be duplicated once, twice, or even more)
If you turn on multicast, the Dante system only needs to send out one Dante data stream which both the broadcast and monitor desk will receive (as well as any other Dante device that the audio is routed to).
Long story short, you are sending a lot more data through the network than you need to due to your choice to use Unicast. My speculation (and it is only speculation) is that the network eventually becomes overwhelmed with the volume of data you are sending and begins to have problems. If this is the case, then switching to multicast will help reduce the amount of traffic being sent over the network.
UPDATE – Dante Clock Issue
I have been monitoring the situation closely to identify when the Dante crashes occur.
The issue can take up to 12 hours to appear. However, on another occasion, it happened immediately after turning on the console.
Every time it occurs, it results in a complete network failure on top of a full Dante audio drop out and clock lost : Qu-Pad (Android) disconnects, and now, with the latest Mac version, the Mac application crashes as well.
It can last between 10 seconds and up to 1 minute and then it goes back to normal.
Except when we were in a live show the crash lasted for 20-25 minutes. We lost a great chunk of the audio recording of this important show.
This suggests that the problem goes deeper than a simple Dante connection issue.
It seems to happen mainly when the console is operating in Dante Network Bridge mode, although it can also occur when using the two separate network ports. It appears to be less frequent when using the two-port configuration.
Interestingly, the audio on the analogue side of the console is not affected when the problem occurs. What we lose is network control, and Dante crashes with a Clock Lost error. However, there is no interruption to the analogue audio or the S-Link connection.
This clearly points towards an underlying network-related issue.
We will now return the console to the A&H and see what they can do to investigate and resolve the problem.
It would also be interesting to know whether other users have experienced similar issues.
Thanks.
I agree that this points to a network issue. I believe your last post was the first time you mentioned combining Dante and non-Dante traffic on the same network. I certainly missed it if you mentioned it previously.
The fact that you are bridging your Dante network with your regular network is the primary cause of your problems IMHO. Dante is designed to co-exist on a network with other traffic, but that network must be set up correctly (following Audinate’s rules and recommendations). You generally cannot simply connect a bunch of devices together and expect seamless data flows when both Dante and non-Dante traffic are passing on the same network. It takes a lot more effort to set up a reliable network when it is passing both Dante and non-Dante traffic together.
The easiest solution (and the one I would recommend) is to isolate the Dante network completely. In other words, you will have two networks - your existing network with only non-Dante traffic on it, and a new network that only has your Dante devices connected. Using a dedicated network for just Dante traffic is much easier to setup than a network that is going to have both Dante and non-Dante traffic on it. If you are using “dumb” unmanaged network switches (that don’t have energy saving settings) for the Dante network, it is pretty much plug and play. It’s only when you start using managed switches, or start combining Dante and non-Dante traffic on the same network that things start to get complicated and you really have to focus on the specific network settings to ensure everything will work as expected.
If you insist on using a single network for both Dante and non-Dante traffic, you really need to go through Audinate’s certification courses (at least level 1 and level 2) to ensure you have a basic knowledge of what is required when Dante and regular network traffic are on a shared network.
Long story short, you should figure out your network problems before you consider returning the console. The odds are extremely high that nothing wrong with your console and all of your problems stem from your network implementation.
PS - you don’t need to use a router with this isolated Dante network. Just use a non-managed network switch to connect the Dante devices together and they will default to using the APIPA address scheme to connect.
It’s unfortunate that there is this bug with the QU-5D’s, I’m hoping it can be addressed with a firmware update, and we don’t have to send these consoles back to get hardware fixed.
Are we even sure it’s not just this one user? I mean I’m worried about it too, but it seems rather unlikely that a very core function in the mixer like this wouldn’t have been discoverd in testing.
I’ve experienced something similar with the Qu-5D, but since I started using the Dante network with this specific device—and am still a beginner—I assumed the issue was my own fault. Fortunately, I have the chance to test the same laptop with an Avantis, which should allow me to rule out both the laptop and my own errors as the cause.
(So far, based on one-hour test intervals, the Avantis has proven more stable.)
Does A&H have any input on this? Have they encountered anything similar, or could these issues stem entirely from Dante-related factors or user error?
Obviously I am speculating here, but IF there is an issue with the A&H system, it is most likely a software problem that could be corrected with a firmware update. I find it very hard to believe that there is a hardware problem. I say that because A&H is likely reusing other Dante components/chips that they have already been using successfully in other consoles. The odds that they designed and engineered a completely new chip just for the new QU consoles is pretty low.
PS - IMHO this is also why A&H is able to offer a 32x32 Dante upgrade for the QU “D” consoles. The Dante chip they decided to use in the QU “D” consoles is probably the same chip they use in their other Dante cards that have higher I/O counts. However initially they were only licensing it with Audinate for 16x16. Now they are offering an “upgrade” in which the user is paying for an “extra” Audinate license to use 32x32 Dante channels.
Bryan indeed it might well be a software issue.
Regardless of software or hardware issue , the console is not operational for professional jobs.
That is why it has to be sent back in any event.
After reading through this treat, here my thoughts:
  • The failure don’t has to be the same in Case 1 and Case 2.
  • In Case 1 (what others already mentioned) choosing multicast-flows for sending the same signals to multiple destinations seems to solve the problem.
  • General: Don’t try to force a clock leader. Let Dante choose it.
  • Use the Dante Controller to solve the problems: Clocking issues are shown and reported.
  • A lot of Dante problems are not ‘too much data in the network’, but conflicts with Multicast / Broadcast, PTP (Presicion Time Protocol: Syncing: Clock issues) what can be solved with managed switches - if you know what you are doing…
  • Dante is very easy, when you use it for small things. When it gets bigger, don’t mix it with other network traffic.
  • Use the Audinate training videos. They are renewed in the last year (i think) and for me it was very helpful to go through level 1 to 3. It’s also a lot of network knowledge to understand, what can cause problems and how to fix them.
Update - We’re still in testing stage but looks promising
Hi All,
Hesitantly we pushed the recent 1.2.1 Firmware update to the console (We did not update the Dante Card) to both of our QU-5Ds and left one running over the last few days (48+ Hours).
This update appears to have stabilised the console.
While there was not direct patch notes referencing this issue, it did have one targeting and issue with the S-Link Clock sync. Based on logs from Dante before the update our mixer’s clock sync would drift to the point that after a few hours it would drop out due to no sync lock. Ever since the update we have not seen this issue in the Logs or had the mixers drop out.
I will admit we are still in the process of testing the unit but the update certainly has appeared to have stabilised our consoles.
Will update once we’ve had a bit more time testing and using the unit.
That’s good news (hopefully)
Keep us posted!
Baspen thanks for your message
Here it is the other way around
With Firmware 1.2.1 r4106, and Dante 1.1.0 it’s worst than ever. The QU 5-D loses clock sync every 10 minutes now.
Again it is the only device in the Dante network to lose sync. All others, a mix of high end Dante and DVS is rock solid.
