QU-5D fan noise
Hello Everyone, I recently put a QU-5D into my studio. It’s been working great but today, I noticed the fans were exceptionally loud, so much so as to be distracting while trying to mix. Has anyone else encountered this problem?
I believe the fans are controlled by temperature. If the fans are running faster than normal, the console is likely getting hotter than normal.
Is the overall environment hotter than normal? If there something specific near the console that could be adding heat? Have you cleaned out the enclosure recently? (If not, you should because dust will work itself in the case and can easily cause the cooling to become compromised).
It’s also possible (although unlikely given how new the console likely is) that the fan bearings are going bad and causing the fan to create more audible noise than normal.
Same issue here, the unusual fan noise is constant (in cold or hot rooms)… Could it be that the internal fan is a budget/low quality fan ? If so, is there a way to remplace it with a new/higher quality one ?
I’m thinking it’s a bad fan. Hoping to be sent a replacement…
Could it be that only the “D” variants feature an additional fan specifically for the Dante module, which, just like the Dante cards for the SQ, is evidently louder than the consoles’ standard fans?
My standard Qu-5 (minus Dante) is in my church sanctuary, and it’s extremely quiet. Always! Even after being on 2 plus hours.
