I ahve hardly used my Qu mixers since the lockdown. I’ve had three gigs with it since August. I cannot get it to connect to the router, and wonder if it could be formware or version mispatch? My Qu-16 is V1.90.(something) and my Qpad is V1.93. They wroked together flwalessly last year. Do I need to update something?
Qpad sees the wifi fine but the mixer does not show up.
Check IP addressing between the router and the mixer.
Try deleting and reinstalling the Q Pad app, after some iPad
IOS updates I’ve seen that needed to be done.
Sorry for delay, Mike. No it did not work. I haven’t had many gigs ecently so ignored it and mixed locally
BUT I found out why:
Here’s a tip: I was unable to connect with Qu-pad recently though I have used it many times before. Did all of the usual things but no joy. Then, poking around in my iPad I found that the Qu-pad settings preferences has a switch to “access local network” that was OFF! No idea how that happened, maybe in an auto upgrade.
Go to Settings and scroll down to the Qu-pad app, open that window and make sure the switch is green!
