Qu and Wireless settings ?
Installed Firmware 1.10. my router is a Belkin - works great with my iLive …
Now i tried to bring it on the QU … Network Tab says. QUs IP is 192.168.1.100 … Subnet 255.255.255.0 and gate 192.168.1.1 … standard. so …100… the Qu´s IP right ?
Connect the Qu Network port to the WAN port of the Belkin.
Belkin is configured as follows:
LAN - 192.168.1.2 - Sub 255.255.255.0
Wireless Range from …2 to 100
I can login and configure the Beklin at …1.2. with no problem - but always got a red light on it - so it seems that he´s got no connection to the QU …
i´m a bit confused… manual says nothing :smiley: … only not supported with 1.01 …
IDR48 & T112, QU16, AR2412 , Dante, Lenovo i5, Samplitude ProX, Pro Tools11
The release notes for 1.10 say to enable DHCP on the mixer. I did so and it works fine. Have you tried that?
mamerica
Mpls, MN USA
Yes, DHCP is enabled but router does not connect to Qu - even after resetting the router to standard settings. will try a different one later today.
A bit more info on setting this up wouldn’t hurt. I’ve got Qu-pad talking to my qu16 via my wifi network but only if the internet connection is up. If I unplug the connection from the Airport to the cable modem qu-pad loses it’s connection to the mixer. Most annoying!
Donmr, I seem to remember that when people upgraded to iOS 6 there were some issues with connections only working when connected to Internet. Have a search of the ilive forum, I remember some solutions were posted.
