Feel silly here, but what’s the equivalent on the mixer itself? I honestly can’t find anything under Processing for each channel.
The Processing information screen reflects the channel where the Select button is pressed or lit.
Did I understand your question?
on the left side is a button called “pre”
if you press a mix button on the right, you can set pre/post with these button
the assign button does similar things for aux on/off and assign to the main mix on/off
a reference is “Getting Started Guide” Page 11
Thanks guys.
Trying to setup personalized mixes for everyone (4 of us) using the stereo Mix busses and the Groups. Working well, but pre/post toggling really boosts the perceived volume in the mixes. Thinking probably post-fader is more manageable while we’re tracking (no PA, just cans), but seems like “pre” is being used to bump up the can mix for some of them.
pre is used when you need your mixes independent from the main mix
I don’t plan on using the main mix at all (Qu-24 is only used in a studio setting for tracking and headphone mixes). But will pre allow muting of channels on say Mix 5/6 that won’t affect Mix 6/7?
Yes, simply unassign them from said mix.
Good luck !
Giga
I tried that, but the mute seemed to be global.
Mutes are global to all mixes. As Giga notes, if you want channels muted in certain mixes, you will instead have to unassign them from those mixes.
ah, ok. Thanks everyone.
