QU as actual StageBoxes
Be able to switch any QU to be an actual Stage Box. No processing no patching having to be done. Put a switch mode and it works like plugging in an AR2412, AR168.
My instance I have an SQ5, a QU24, and a AR2412. QU24 and AR2412 was my initial setup. Upgraded to SQ5 and now my QU sits it out. Setting the QU to be a Stage box now I have plug in play 2x 24 inputs.
Also I can see the QU-SB and SQ-pak being the size they are similar to a stagebox. Just switching them to stagebox mode would work great when upgrading to SQ and not having to buy new stageboxes.
You’d only be able to have one Qu per setup, as they can’t take an external clock.
I’d still be very happy to see that though.
Correct would not be able to cascade the the AR2412 and the QU24 as it is over 40 input limit. I have an Slink IO card to do the split.
