Qu-Drive Compatible USB Device Database
@MikeC
I had considered that until the first USB did work.
That was the really olde one from Staples and was a USB 2 white box unbranded memory stick.
That tells me it does work.
I see signal to the Qu drive like its trying to be ready to write to it.
I get a blinking light and error messages about the USB memory which indicates the drive is working.
@MikeC
Did not get the messages you noted earlier. Never said unsupported.
I have no idea where the problem is but suspect it is a combination of AH hardware and firmware together with something about the memory sticks.
Remember, I am not the only one having problems. Read the forum here. Read the one at prosoundweb. Read gearslutz.
AH has problems with USB memory. I am the victim not the culprit.
<< Keep in mind when you put in a fresh new clean USB stick “Data Traveler” and the QU looks at the USB stick, while you are in the format menu it will say “unsupported please format” you then hit the format, it ask you to confirm the format, hit yes and away it goes, after it formats it will do a drive verification and then say OK.
Attached are some pictures I took of formatting some extra drives I had this afternoon, all worked.
Not convinced yet you have a problem with the mixer.>>
Remember, I am not the only one having problems. Read the forum here. Read the one at prosoundweb. Read gearslutz. AH has problems with USB memory. I am the victim not the culprit.
The QU is picky at what USB drives it likes, as are some other digital mixers content removed – does not contribute to the thread
I’m sure there are other USB drives out there that work fine in the QU but after the Data Traveler series has proven itself that’s what I have continued to use, why re- invent the wheel.
Are you really doing all of the correct steps to actually format the drive like I show in the crude video I posted to YouTube?
You have never really given us the step by step steps you are taking to format a drive other than saying they fail and then eluding to other menus and functions that have nothing to do with formatting a drive.
@MikeC
AH can be picky about recording 18 channels at once,
but not so picky as to refuse to acknowledge the drive exists and format it for a slow back up.
I am doing everything the manual said to do.
When it gives an error message I stop.
The time we did format one successfully all the signs leading up to the format were different.
I am not at the point of formatting because it gives various error messages so I do not try to format it.
Are you saying the error messages are wrong and just format anyway. How can we then be sure it will work correctly when we use it. How can we be sure that if we restore the backup someday that it will really work?
Put one your fresh Data Travlers in the QU Drive, while in the format menu, give the mixer a few seconds to look at the drive.
Disregard the warnings and proceed to hit the format button and hit yes to proceed, after it formats give it 30 seconds or so and it will verify the drive and say OK on the screen. Your good to go then.
Do pull the drive out the first second you see a warning pop up!!
IF you try to format a drive and the progress bar never moves at all after a few minutes, (give it chance) then that drive is not going to format, pull it out and move on.
@MikeC
you sound like you are saying that the AH programmers are idiots and that managment are all PHBs
NO I’m not…the display warning is legit as at the time it is displayed the USB drive is indeed incompatible…until you follow through with the format process.
Try it.
@MikeC
Most people would say a message of incompatible means incompatible and stop there.
If what you say is correct then they should say needs formatting and proceed with formatting y/n?
I am correct…try it.
If by chance the drive you try is indeed corrupted trying to format will not hurt anything, it just will not complete the format.
content removed – does not contribute to the thread In the video I linked to showing me formatting a SE9G2 Data Traveler. I mentioned and showed the message an then went on showing the format process.
@MikeC
We did try it.
It worked once. WITHOUT ANY ERROR MESSAGES.
The others did not.
You may have gotten it to work after an error message.
But the messages I get tell any logical person to stop.
You might get it to ‘format’ BUT CAN YOU TRUST IT WHEN IT FIRST SAID IT WAS NOT SUPPORTED OR NFG OR …
If you are correct then AH has a totally screwed up UI with bad messages and needs to fix that in firmware instead of having a mostly useless database of supposedly working USB drives.
But I still say that with all the complaints here, prowebsound, gearslutz, and other fora that the problem is NOT ME.
@AH
are your error messages what is causing the problem so many people have with USB memory?
shouldnt you fix those with some firmware changes and stop confusing people ?
if it is not the problem then please just tell us what all y’all did that so many people are having problems.
We did try it.
The others did not.
You might get it to ‘format’ BUT CAN YOU TRUST IT WHEN IT FIRST SAID IT WAS NOT SUPPORTED OR NFG OR ……….
What do you mean by “worked once” and “the others did not”
In spite of the error message did you try to format the drive anyway.
Did you take the other drives that were fresh and then dick with them in the computer and now they will not format?
@MikeC
As I have said a number of times we got ONE USB to format and that was a white box Staples no name USB 2 with 8G.
Note what AH officially said:
Profile photo of Nicola A&H
Nicola A&H
<< You may need to first format the USB key on a PC or Mac (FAT 32), then try to format it again on the Qu mixer. >>
Just because you have been lucky does not make all the other people having problems incompetent.
Did you or did you not ever get a Data Traveler to format?
And what this poster said:
@Dick Rees
Since the console does not recognize the USB disk when it’s inserted, it’s not possible to format it on the console.
It has to read the USB disk first before you can format it. If it does read it & it was not formatted it will read “unsupported format” or something, according to the manual.
… Odd thing I noticed is that the LED on the QuDrive flashes very faintly when the USB disk is connected, but still says “No USB disk present”
Otherwise I will have contact A&H directly & see how they can assist. I’m situated in South Africa, not sure if the voltage here can cause issues on the console, but I very much doubt it.
THE RESULT:
Profile photo of Hanroux
Hanroux
Participant
I visited the South African agent for A&H today & had a long technical session with the local A&H brand manager, who is also a sound engineer & very familiar with the whole range of A&H digital consoles himself. The USB disks that he uses to update firmware for the Qu consoles also did not want to read on my Qu24. So alas, I had to let the faulty console go & I’m very happy to say that they replaced the faulty console with a brand new Qu24. The one I’m using at the moment is working seamlessly with all the USB disks that I have, as well as an older 500GB HD – no problems from the start whatsoever.
I never would have thought that the console would be the device at fault. The A&H brand manager was just as surprised as I was, said it’s the first time he had to deal with an issue like this where a Qu console did not want to read any USB disks whatsoever, even ones that were formatted in QuDrive format.
APPARENTLY ITS THE QU CONSOLES THAT ARE AT FAULT.
Isn’t it time for AH to come clean and fix the problem with a proper firmware update?
And again you never answered my question.
@MikeC and @xyz, as I’ve written in this thread previously, I’ve spent hours on the phone with A&H tech support walking me through every step, using freshly bought drives. I’ve got a SanDisk Ultra 32GB USB3.0 drive sitting in front of me right now, still sealed in its packaging. Would you like me to video what happens when I open it up and put it into my Qu16? I can guarantee you from long and painful experience and a lot of wasted money that it will not work; it will either fail to recognize the drive at all, or it will hang when it tries to format. (By “hang” I mean that I can come back two days later and it will still be no different.) Why this and not a Data Traveler? Because this drive was one that many people claimed was working for them.
This is a very long thread. I have read every post in it, many of them several times. The problem is not operator error. The problem appears to be that some Qu consoles are lemons and others are not. Volounteer and I both seem to have gotten lemons - as have many others posting in this thread.
I don’t use Sandisk Ultra. If I remember correctly… They were the shorter blue memory sticks? And I did have enormous problems with the Ultra… In fact I gave them away to a friend.They worked fine on PC Mac etc…
I only have used Sandisk EXTREME.
@mikec and @xyz, as I’ve written in this thread previously, I’ve spent hours on the phone with A&H tech support walking me through every step, using freshly bought drives. I’ve got a SanDisk Ultra 32GB USB3.0 drive sitting in front of me right now, still sealed in its packaging. Would you like me to video what happens when I open it up and put it into my Qu16? I can guarantee you from long and painful experience and a lot of wasted money that it will not work; it will either fail to recognize the drive at all, or it will hang when it tries to format. (By “hang” I mean that I can come back two days later and it will still be no different.) Why this and not a Data Traveler? Because this drive was one that many people claimed was working for them.
This is a very long thread. I have read every post in it, many of them several times. The problem is not operator error. The problem appears to be that some Qu consoles are lemons and others are not. Volounteer and I both seem to have gotten lemons – as have many others posting in this thread.
I don’t know what the internal hardware differences are between different models of drives that are causing some brands not to work at all or even with in the same brand some models working and others not.
I have never tried the Sans Disk USB model you have. I have and use a Sans Disk Extreme USB 3 model that works great. I got that a couple years ago after being recommended here. I have since heard that the current Sans Disk Extreme USB3 drives no longer work, I’ve have not tried a new one.
Don’t even try the Sans Disk Cruzer drives!!
I know exactly what you mean when the formatting process “hangs” forever, I’ve seen it while trying some different USB drives.
After early on finding that the Kingston Data Travelers all have worked every time I quit trying other USB drives.
The only thing I can say is get some new Data Travelers, open the package and go straight to the mixer and format.
@MikeC
I found a statement from AH that says they blame chip differences and other manufacturing aspects as to why some work and some dont when they are the same brand model sub model and size.
I also found one that I posted that said a dealer said it was the console’s fault.
@MikeC
We have had ZERO Kingston work whether Data Travellers or other models.
We have had ZERO SansDisk work no matter which type we tried.
We have had some others fail.
The ONLY one that worked FOR US is a white box no name Staples generic USB memory stick of 8G
