Since i used a SanDisk Extreme 64gb USB3.0 succesfully over a year now, i noticed that the stick is not recognized anymore. multiple reformats (yes, on a pc, yes, fat-32) later and attempts to reformat no the desk, hard resets and backups the stick that has worked for over 1,5 years now just is not recognized anymore.
the formatting process gets started, shows no bar movement and is stuck immediately. either the stick is not recognized on plugging in (LED blinks orange, then turns off) or it is still recognized after plugging off (orange LED stays on, even when no stick is present)
My main idea is that allen&heath uses a faulty USB interface on board that starts to malfunction due to component ageing and cheap chinese manufactureing - or i m going crazy
because the very stick in your compatibility list - WHICH WORKS ON MY PC - is not recognized anymore, cannot be formatted anymore and has no visible content to the desk under any circumstances
so should i now invest in a SSD, knowing that there is a whacky USB interface in the board which might or might not recognize another 100 euro investment?
can ALLEN&HEATH specify the USB internal so we can at least order replacements on alibaba once the warranty is void? how does one deal with this?
Do you/have you used that stick for any other uses that recording on the mixer and then transfering files to the computer or loading files on to it for playback?
Do you have any other USB sticks to try or that you have used in the mixer?
Get another USB stick to try before going crazy on the mixer.
The two USB sticks I use are the San Disk Extreme like yours and the Kingston Data Traveler series. So far all of the Data Traveler models I have tried have worked.
This can be the crux of the matter. It’s WAY too easy to pick up something bad on USB media from an infected or compromised device. I don’t accept random sticks for playback when doing festival sound without scanning it first to weed out viruses, trojans, etc.
All my sticks are SINGLE PURPOSE and have been functioning to spec for years.
absolutely never used the stick for anything but recording and replay on the mixer, it was either permanently stuck in the mixers qu-drive port or used to transfer files to the PC using a renkforce USB hub for fx editing and rerouting into them mixer via live.
i also suspect that the USB interface might have power issues over time, degradation of parts usually makes running power into a device problematic which anyone who has used a cheap USB-hub or underspec´d motherboard components running multiple USB devices might have experienced. i guess my best guess will be to try an external USB 2.0 hd if i find one and run it with extra power supply.
a trojan or virus that has hogged the USB device management of my PC might be very realistic. and might explain some missing file space allocation that my stick does not show, but which can also be accredited due to normal decay of a drive. then there were multiple holes in the intel architecture that might allow this to happen which we all can´t really defend against. “SPECTRE/MELTDOWN”. so you can guess that i m bamboozled especially after having used a stick with the most prominent reviews here.
i d really love for allen & heath to code their own usb-stick formatting tool. in the meantime i m looking at either buying a stick or doing a full backup - erase - reinstall with 500 gigs of samples and a lifetime of plugins purchased to get that bug of my system which might affect my USB component… who knows.
i have tried the seagate 2tb backup slim which is supposed to work with the device and as this one does not recognize or format on the desk - usb gets hung up - i assume it is the usb port or firmware
a pendrive virus is improbable, as most of the devices i use are not on the list of badusb compatible devices. which does not say much but makes an improbable cause even less probable
On my QU-SB, I eventually ordered a new USB jack and installed it. This fixed a non-functioning USB port. It had definitely degraded but in my case, it was a physical problem. I had noticed that stick would be recognized if I pushed on it a bit in a certain direction. That trick eventually stopped working so I changed the USB jack.
My Samsung T5 SSD that I use for performing multitrack recording is also used for the purpose of playing back downloaded films from my iMac via my PS4. Been doing this for quite sometime without any problems occurring. Must be honest though, I don’t use the USB function for multitrack on either my QU-16 and/or QU-SB all that often and mainly when I have been hired to provide PA etc will I use this function. If for my own band I don’t multitract at all as I have a small USB inserted all the time for the purpose of play-on and the QU can’t record and playback at the same time.
That would be best, as a faulty USB port is quite likely.
If I were you, I would first try a forced firmware update as a last resort:
To do this, shut down your console, insert a FAT32 formatted USB stick with only the appropriate firmware-QUU-file into the USB port, and turn on the consol while holding down the USB button (under Preamp) and the In button (under HPF) until an update might finally start.
I run the QU-SB, therefore this way of forced fw update is not possible for me. there’s a button to do this but I doubt it would work since the unit don’t read the drive at all…
nevertheless, I have some hope for everyne with a similar problem. Today, after several days of agony, I noticed the USB LED light went of, so I inserted a formated drive and guess what - everything works as it should since!! the only thing that I did different today is that instead of my regular wifi router I used an internet-connected router. my assumption is that the unit needed to go online for a bit to fix the problem itself, although I haven’t tested this in depth to say for sure. good luck to everyone experiencing similar issues!
With the QU-SB, you would instead have to hold down the Firmware Update button while switching it on until the LED lights up green.
I would rule out the possibility that QU can establish an internet connection, and even more so that this would activate an automatic remote healing process.
But it’s good for you that it’s working again, for whatever reason.
A&H’s USB recording stack is famously and nonsensically bad. Using the USB out to a laptop running the DAW of your choice is a much more reliable option.
