Qu-Pac External Control??
Can the Qu-pac be controlled from an external midi controller? I think the ipad control of the unit will be suitable for most of my situations but there are times I would like to have faders. I know Behringer is releasing the X-Touch one of these years and I was hoping to be able to use with the Qu-pac.
Cheers.
From the midi protocol document of QU-series
The following Qu functions can be controlled via MIDI:
 Mutes
 Faders and Pan
 Mix and FX sends - Level, Pan, Assign, Pre/Post
 Matrix sends – Level, Pan, Assign, Pre/Post (not Qu-16)
 Audio Groups – Assign (not Qu-16)
 Mute Groups – Assign, Master Mute
 DCA Groups – Assign, Master Level, Master Mute
 PAFL select
 Input Channel source
 Preamp (local and dSNAKE) – Gain, Pad, 48V
 Insert In/Out
 Input Channel processing – Trim, Polarity, Gate, PEQ, Compressor, Delay
 Mix processing - PEQ, GEQ, Compressor, Delay
 Group and Matrix processing – PEQ, GEQ, Compressor, Delay (not Qu-16)
 Channel Names
 Scene Recall
 FX Tap Tempo
 MMC Transport Control
Not sure that the X-Touch can be configured to match the Qu MIDI Protocol. I guess it can work with a DAW which can be configured to follow the X-Touch protocol, but the Qu(Pac) is not a DAW and does not allow its MIDI protocol to be adapted for some control surface needs.
