Thanks Mark - if I’ve got it right, the front of the Qu-Pac protrudes by 5cm past its 19" rack brackets, so the case lid should be at least 5cm depth.
Still interested in any user comments/issues on Qu-Pac cooling inside the rack flight case? I took some extra care with air flow on my Qu-24 flight case.
Looks like A&H have used a shallow 4U ‘Cobra’ case in its promo photos?
Regarding heat I saw several QuPac running whole day on Musik Messe, inside case and standalone, obviously without any problem. Well, it wasn’t summer and the temperature inside the hall wasn’t that high (below “concert level”).
Summer open air with sun shining on a cased QuPac will be a different situation, though.
I’d personally be too paranoid to not mount some small fan inside the case to enforce some airflow, not after touching them on the booth…
The Qu-Pac fits in these SKB Roto Moldded Shallow Rack cases - there is enough clearance in the front cover to accommodate the angled face of the unit.
It was hard to tell from the measurements provided, but I ordered one anyway and it fits.
Sure thing. I will try and post this upcoming week. FYI there is plenty of room for cables in the back for my purposes. I have an 8-port PoE router with an Neutrik ethercon faceplate, apple airport express, and the Furman power conditioner with room to spare to pack cables in. You aren’t going to be storing huge cable reels or anything, but it closes in the back with no problem.
