Hey guys
I have a problem with connecting my ipad with the Qu-16
I read and follow all instruction for connecting but it doesn’t work
So maybe someone can help me
Qu-16 Firmware 1.90
Qu-Pad version 1.91
No problem with the connection between the router and qu-16
Also no problem with the router and my ipad
In the app i find the qu-16 mixer only when in the mixer dhcp is disabled
But it find the mixer
But then when i want to choose the user it appears:
Connection Failed
Connection Error
The manual said when this appears it means that there are more than 8 devices in the same network
But i’m really shure that is only my iPad
Maybe an IP address issue. You say it only connects when the mixers DHCP is turned off, what is the static address enter into the mixer. How is the router configured, IP address, DHCP assignment range.
Similar problem here. Qu-Pad on iPad works fine, as does Mixing Station on Android 8.1, but Qu-You on Android 8.1 can never connect, just gives ‘Connection failed’. Doesn’t see the Qu-16 on the network and if you put in IP address it makes no difference.
Qu-16 1.93
Qu-You 1.90 on Android 8.1
Qu-Pad 1.92 on iOS 11.2.2
Mixing Station 0.001.32 (44)
I had a similar problem this evening. I downloaded the qu-you app on my phone, connected the phone to the router, launched the app, and connected to the mixer. Everything worked fine. Adjusted levels from my phone and watched the faders on our Qu-32 move.
Then, I got our worship leader’s phone to get him set up. Everything is fine until I launch the app and the Qu-32 does not appear on the list (only options are “demo” and “other”).
So, I am holding two Android phones in my hands, both connected to the same router, both running the same version (v1.90) of Qu-You. One connects and runs fine, the other can’t find the Qu-32.
There are no other devices connected, so it’s not an issue with too many devices connected.
It’s probably a phone setting, but I have no idea what. Anyone have any ideas?
I’ve seen some Androids refusing to connect to a router that has no internet connection. There is abutton somewhere to overrule this preference. Hope this helps so good luck !
I got a connection problem between my iPad and my router.
It connects for a few minutes and I can control the board through the wifi, but suddenly it dissconnect and the Qu-Pad app says Connection Failed and Connection Error.
What did I do wrong?
Why does it drop out of the connection?
It’s kind of urgent, so I would really appreciate a fast answer.
You might try setting the routers WiFi to a different channel. You can install apps on your iPad that allow you to see what channels are the least busy.
