Qu-Pad - How can I achieve anything else but a bell shape on PEQ?
Hi there
Am I missing something or can one NOT adjust the Width/Freq/Gain sections on PEQ on Qu-Pad app by touching the Green/Turquise/Blue/Red number areas?
You can only pull the wave forms circles up and down and so cant really single out EQ issues?
You can get shelving filters by moving the soft Q controls to the extremities. The superstrip doesn’t allow this.
EDIT: I should mention this is only the cases for bands 1 and 4, which provide low and high shelves respectively.
I’m on about with the Qu-Pad iPad app here.
It’s a pinch action.
I usually put one finger on the dot that represents the band I want to change, and the slide another towards or away from it.
Oh yeah, well done again Mark.
Still a bit fidly mind you isnt it, and I cant quiet get the band as narrow as I want, but its a lot better.
Shame you cant access the numbers to adjust them either. (Or slide over the numbers)
touch and slide a virtual fader on the numbers would be good…
You can pinch anywhere within the EQ grid. Select the band that you want to change by touching the dot.
Place a finger near the upper left corner of the grid. Place another finger (even from a different hand) anywhere within the grid and move it left or right.
You can pinch anywhere within the EQ grid. Select the band that you want to change by touching the dot. Place a finger near the upper left corner of the grid. Place another finger (even from a different hand) anywhere within the grid and move it left or right.
Totally, but virtual faders would defo be handy too though as its still not the easiest of things to do especially during a live performance.
