Hi.
Can anyone advise me on how to make the Channel HPF visible (and therefore adjustable) in the PEQ window?
I have HPF IN engaged but the purple dot doesn’t show.
This is whilst using the Demo Mode on my iPad and is not connected to my Qu24.
Cheers for now.
I just looked at this and it could be considered a small bug, as in demo mode, the HPF default value is 4Hz - which is off the screen.
We’ve probably not had any complaints about it however, as in use (when it’s actually doing something) this wouldn’t be the case.
I’m trying to think why you would need to adjust it in demo mode - is it for teaching or screenshots of suggested settings?
Hi.
Thanks for your reply.
I’m just re-familiarising myself with the interface.
Its been a while since I’ve used it…
I was gigging on Saturday and found myself hunting feedback while still playing my guitar.
I realised how out of practice I was.
I also realised that, sometimes, one brain is not enough.
Cheers for now.
Ran across this issue myself recently. Indeed, the HPF is 4Hz and thus not selectable. To correct for this error, double tap the “4.0 Hz” text and a popup will appear. Choose “Reset”. This resets the HPF to 100hz allowing you to adjust it.
