3 custom fader banks is not enough. I run middle school instrumental music concerts and, using Master Fader up to now, have a different fader strip “view” for each type of band. MF has 4 views, which is just enough for my needs. 3 is too few. Ideally 6-8 custom views would be great. It seems like the storage requirements for a customer fader configuration is small, so why not add more than 3?
It seems to me that rethinking how to make the best use of what ís available could go a long way. For instance: why not change customview 1 while you’re mixing on customview 3 ? Or prepare a few scenes/shows that have the settings that you need in them ?
In addition to above suggestion to (1) add extra custom panels, I request the ability (in a style similar to scenes & shows) to save Qu-Pad Custom settings on:
(2) the iPad’s app config storage locations, if not
(3) the (sage able) Qu-Drive when mounted to the mixer perhaps using MIDI sysex, if not
(4) the shareable cloud (googleDrive shared dir, etc), could be helpful additions/alternatives.
I believe A&H’s 3 custom panels are a clever workaround against the inability to move each annex to a custom location. The ability to store data presets/configurations locally, on networked hardware, and even various cloud platforms has been relatively ubiquitous for years.
The ultimately flexible solution would be a combination of all four suggestions, but…
of custom layers. Use two iPads. 6 custom layers (any 2 simultaneously) plus the main layer = 7 control configs and the flexibility to see two at a time or work on one while you configure the other.
Scenes as Giga suggests.
I’d rather see processing upgrades before getting into control issues in the app which serve a minority of users. Features such as a downward expander option for the gates, multi-band and/or frequency sensitive compression, HPF on mix/group outputs, etc.
