Qu Pad "on" button
On the qu pad app, on the input screen, what does the “on” button in the slider section do?
It enables that faders output on the given mix. On non LR mixes there is also an Pre/Post fade button adjacent.
One example of usage might be for a bass guitar, I want to put the signal back to the bass amp, but don’t need it in the FOH setup, since the speakers can’t deal with those frequencies. I can put the Bass amp on Mix4, with a post fade send from the Bass channel.
Then I take the Bass channel out of the main mix - but the fader still does the right thing, the volume is controlled normally, but the sound comes from the Bass amp, not the FOH speakers.
It’s therefore much less “aggressive” than a mute button.
Does that help?
(Note that the mixer has this option when you go to a mix on the right section, then hold down PFL or Assign and tap the select buttons for each channel)
Yes. Thanks.
on analoge mixers,
there are buttons to assign the channel strip to groups 1-2, 3-4, 5-6, 7-8, etc. and also L/R.
The green button you are talking about is the same thing as a common “L/R” button.
Dan
dpdan - yes, although I recall those normally being group sends on the mixers I’ve used - which is why they didn’t occur to me (since the mixes on a digital mixer are more normally compared with aux outputs on an analogue desk).
