Hi
We have a QU SB , main use with 3 inputs on which all have FX reverb applied via send and return.
We have physical switches for all mics for easy on / off
I recently installed a monitor speaker and noticed
Whilst all mics are off using the physical switch no sound signal is registered on the qu pad. However, the mic remains which I believe is the reverb. I tested this by muting the mics on the room mix via the qu pad.
All mics muted however a reverb was registered into the mic and could be hears via speakers.
This also now means that the monitor speaker is also registering frequency from the mics even though the faders are all completely down for 2 out of 3 mics.
Any suggestions
Ive tried the insert instead of send and return however this changes the way the reverb sounds and also only apply to a single channel
