QU-SB Mono Out question
I haven’t gigged with the QU-SB as of yet, being the tourist OFF season, So what a good time to learn a new mixer. I use a BOSE L1M2 as my PA system. So now that Ive got my mixer tuned in just how I like it, I wanted to ask if there is a way to send a MONO OUT signal to the BOSE?
I know I can Pan everything to L or R, but prefer not to do it that way, if I do it that way my QU-DRIVE recordings are also effected. I noticed the MONO OUT XLR on the back of the mixer which I assume are MIX outs.
So to simplify my request, I want a complete EQ, FX, and all channels to route through one connection.
Thanks in Advance for any help you can I’ve me.
On your I/O routing tab, configure your Alt Out bus as L+R. Connect via either L or R Alt Out jack using a TRS>XLRm cable.
Thank you, I will give that a try when I get home today, it’s kinda great having a place where people can share experience.
Thanks Again!! Your solution makes total sense :slight_smile:
sorry, another stupid question, Im looking at the image of the back of the QU-SB, its doesnt have an ALT OUT like on the QU-PAC
sorry, I just figured it out, you gave me the answer, I just didnt read it correctly
Sorry, I was thinking of Qu-16. L+R on the SB is only available via the dSnake out. For now just look for L+R output routing options.
Alternatively, use a mono Mix set to post-fader.
right, setting the mono to POST would include all the EQ and FX
Setting the channels to -post just means that the Mix mix will follow the L/R mains bus. You still need to return the fx to the Mix as well as the L/R. The post-fader option simply means that your mono Mix mix will follow level changes on the mains bus. Any routing such as fx needs to be addressed per bus.
Whewwww… when i get this setup, I’m gonna save the scene everyplace! :slight_smile:
