Did you format the usb in the device first before recording?
Did you do this to get it to playback?
Play back Stereo or Multitrack – Patch USB as the source to
the channels using the Processing screen Preamp source
popup. Select ‘Qu-Drive’ as the Global USB Source.
Yes I formatted the USB DRIVE.
it records because I can see it in the app but I can’t get it to play back.
Could you please explain step by step what I have to do.
What I did was pick an input channel, clicked on input source, clocked on USB, (under local, dsnake, USB) then clicked on QU drive in the bottom left hand side. Now the input channel has changed from Source to QU Drive. (Channel 10 in this case) see pic attached.
Is this correct?
If you just recorded a stereo board mix and not multitrack or just want to play audio files (they must be WAV) that you loaded into the playback folder assign the QU Drive to ST3 and not a mic input on the input patch screen.
If you open up the QU Drive on the mixer and look in recordings can you see the files that you recorded?
For full QU Drive multitrack playback you need to assign it to channels 1 thru 18.
I am struggling with the same issue. I have made a recording yesterday and wanted to listen it back. I can see the file in the record folder. How can I put it in the playback folder. I can listen to the recorded file on my laptop but not via the QU-SB.
ST3 was local, now I have set this to QU-Drive and that works.
Only the sound is very weak, where do/can I adjust the incoming recording sound that I want to record the next time?
If I have a matrix available I will assign a matrix out to the QU drive stereo recording input.
The matrix will give some more level control and full processing to the recording.
Mike, that should be a good solution. I think I have a matrix free if I understand you well (my English is not that good). Matrix 9-10 is this correct? They are fee. I don’t know yet how to assign this but I will try to figure this out.
