Qu sb with hardwired i pad
Hello to the community
i saw a post on this forum that let me think that i can use my qu sb without using wifi so i tried what i understood of it but it didn’t work if some one can help me i will be very gratefull.
i tried this :
Ipad2 > usb adaptator > usb ethernet adaptator > ethernet xover cable > qu sb ethernet port
Qu pad ask for an ip adress there is this one 192.168.1.100 i tip ok and then qu pad tell me connection failed…
why are you set up a new thread about this?
we were trying to help you in the other thread already
did you read the answer there?
No thanks !!!
I asked the support of Allen and they told me to start a thread sorry!!
i’ll have a look right now.
Everything is ok now
One little thing that maked me crazy the qu sb ethernet cable as to be plugged inside a regular ethernet plug inside the router and not the internet one. (THANKS KEITH)
As for the harwired ipad :
Configure the router as describe in his manual
Connect the qusb with rj45 cable to a regular ethernet plug of the router (not the internet one)
Connect your ipad to an usb adaptator (that has a plug for power supply)
Usb adaptator to ethernet adaptator
Ethernet adaptator to a regular ethernet plug of the router with an xover cable
Done… easy but sometimes silly things goes in the path…
