Hello,
I am using the QU-YOU app on iPhone and Android for all musicians to tune their IEM mix.
I am not using the main view with the 4 big relative knobs, but the assign view, because our musicians want to tune more than 4 tracks (sax, guitar, mics, drums, bass etc…)
But is it possible for you to add the DCA volumes in the assign view ??
So I can for example do a premix of the 8 mics DRUMS. The 2 keyboards. So the musician will be able to change the drums or KB volumes directly from the assign view
QuControl does not exists on Android.
Yes It should be good to have those 4 relative big wheels, in the same screen with the other tracks in the assign view too
So you can use the 2 together
Hello ,
I am in charge of audio in my church and have been enjoying our qu-24 however i have recently tried to Use DCA’s on the mixer by setting it up in the custom layer. i assigned the channels to the two DCA’s i want to use and two faders in the custom layer but when i move the DCA fader it doesn’t seem to control/adjust the volume on the assigned channels for that specific DCA. Muting the DCA’s work but i don’t understand why the assigned channels are not being adjusted when i move the DCA Fader and i do have both DCA’s set to “in” when i set it up in routing. I’m trying to learn as much as i can , is there something i missed that i need to do?
My first guess would be that what your listing to are any prefade mixes from the channels your controlling with the DCA.
