QU16 to OBS to YouTube
What is the best routing for a livestream to YouTube? I find lots hiss and distortion when feeding into OBS even though the level bars are below yellow. I’m using the Alt out form Mix 9/10 to the mic line in on PC.
Why not simply connect the QU16 to the PC using the USB ?
As I suspect a lot of the noise/distortion you have is from the mic input on the PC (and sounds a bit to me like you might be trying to run a stereo unbalanced signal in via a single mono mic input)
