Hello everyone,
I am hoping someone can provide me with a clear idea of what exactly is necessary for the setup my church is trying to use for livestream.
The proposed setup was:
Qu24 (mix 5-6) –> USB B –> Ableton Live (on a Dell Inspiron laptop) –> Scarlett 2i2 3rd gen –> Mogami Gold Stereo Breakout/ Insert Cable 3.5mm TRS Male to Dual 1/4” TS Male L/R –> ATEM Mini Extreme (mic 1 input set to line level)
I was alerted to the issue of level mismatch between the Scarlett 2i2 (professional level output) and the ATEM (consumer level input). I have been going back and forth with Gemini to try to figure out the optimal solution (which I previously thought was the one I outlined above), but in double-checking before making purchases, I realized it may not be. Anyways I’m about to pull my hair out because it seems like every solution I think might work ends up presenting some problem. I am trying to not add a lot of expenses on top of what the setup was going to cost (was going to be purchasing the mogami cable and the scarlett 2i2).
Another solution I came across was using two attenuators (20dB, one for left and one for right) out of the scarlett 2i2 into two adapters, then into the mogami cable, and finally into the ATEM Mini Extreme.
Are either of these solutions going to result in clean, professional audio, without major level mismatch issues, noise/ hum issues, or phasing issues (this last one is the reason we need a new solution, because our current setup has a phasing issue).
Thank you in advance!
Jacob
