QU24 Mic vs Line level connections
Hello all, newbie here.
I once a month mix at a location that has an QU24. All connections are made via an analog snake which is located close to the stage and where the speaker processors & amplifiers are.
Most nights there is (also) a DJ playing using a Xone92/96 or Pioneer DJM series mixer.
The way the DJ mixer is connected to the QU24 (via the analog snake) is simply 2 channels on XLR coming in from the DJ mixer master outputs.
The 2 channels on the QU24 are connected to the mic XLR input sockets the same way you would do on a SQ5 as the SQ5 doesn’t care about mic vs line levels and there also is a pad switch in the gain stage as I remember correctly.
But the QU24 has separate 1/4 jack line inputs. Are they just for convenience of connecting things and parallel to the mic inputs or do I have to use them for line level signals? (impedance and sensitivity different?)
I can’t seem to find my answer in the manual…
Thanks/Cheers
@HansdNL
The TRS 1/4" Jack inputs on the Qu series are for line level signal - they include a fixed pad and prevent phantom power being inadvertently being sent to the outputs of the connected device.
https://www.allen-heath.com/content/uploads/2023/06/Qu-Mixer-Reference-Guide-AP9372_10.pdf#page=13&zoom=auto,-274,425
For the setup you describe, it would be best to avoid switching connections around by simply using a DI box (or two) at the stage.
Cheers,
