Qu24 + Qu16
We have the Qu24 with the AR2412 and the Qu16 with the AB168. What would be the best way to set up the Qu16 as the “inear” mixer to use with Qu-You for about 8 people? All of the outputs on the Qu24 are occupied. Thanks in advance.
With those two mixers you will need to use a splitter snake, If the QU16 will be on the stage you may not need to use the AB168 but just go direct to the mixer.
Keep in mind you could use the ME monitor mix units with the QU24.
