QU32->D-SNAKE?
i would like to know technicaly the difference between connecting the PA directly to QU 32 MAIN OUT R/L and connecting the PA to the d-snake ar2412 outpouts.
Because of the gld preamps on the Dsnake will I have a different sound? please advise
sure, input stages differ between Qu and AR, not sure if there is any significant audible difference for live applications (except the AR does not have line inputs). Not sure if there is a difference in output stages, though.
I’d expect few samples more latency for signals running through dSnake, still prefer the connection with the shorter analog cable.
Basicly the pre amps have to do with the mic inputs not on the outpouts.i dont think there is any pre-amps on the outpouts…
The distance will be longer taking the signal from the mixer to the speakers…
No doubt the output electronics will be slightly different - but if you can pick up that difference then your ears are better than mine!
Assuming the signal has to get to the same place then I’d expect no difference - it will stay digital for a few tens of metres longer, but have a few tens of metres less far to travel in the analogue domain.
Thank you guys…
coming out either from the mixer either from the D-snake for wich distance we can say we have a high quality of DIGITAL signal?
Also for a distance of 50m is it proper to use stranded cable?
Thank you
Stranded cable might as well work on longer runs, and transmission stays digital between the Qu/Gld and the dSnake boxes in any case. Sound is same for a 1m jumper cable or 10km run via optical fibre.
