Qu32 sending group outputs to studio monitors don’t hear channel compression
I have some monitors connected to group 1-2 outputs and when I go to channel processing for a drum machine I hear the difference if I mess with peq, gate, but if I put the compression in I don’t hear it doing anything. Do I need to set the group to post compression somewhere?
I believe you need to set that channel’s Direct out source to Post Compression.
Do you have group 1-2 in group mode or mix mode.
In group mode you should get all the channel processing of each channel
assigned to that group.
In mix mode you can change the pick off point of the mix out ob all the channels assigned to the that mix.
Thanks guys! Found it in the group routing page. Channel source was set to post-eq. Moved that to post-all and now I hear the compression.
