Quick question: I am using a QU32 with the AR2412 dSnake. Is the monitor output on the dSnake compatible with the Behringer P16 Interface?
No. Proprietary Formats. At most you could run the analogue outs of the 2412 into a p16I and go ultranet from there, but then you can’t use the outputs of the 2412 for anything else (unless you y-split from them, and then you’d have the same signals as in the ultranet.)
