QU32 with direct connection to internet
Hello,
Please forgive if this has been answered elsewhere. I have been unable to find references on line.
We are a church setting up a new QU-32 for live sound and exporting to video streaming.
My question is regarding setting up QU-Pad connectivity via wireless router, internet connectivity and on-line security.
Specifically, is there an issue connecting our QU-32 from the Qu network port to a wireless router which in turn has a connection to a local network and the internet?
The QU-32 reference guide shows a diagram of a closed network between the Qu-32 and the wireless router, with no other connections. Assuming our network has a good firewall and strong passwords, is there a problem with the QU-32 having connectivity to the internet either technically or for security?
Lane
No there is not, I have set up Qu’s and other digital mixers with them on the facilities wifi network. You should get with your IT person and look at setting up the mixer with a static IP address, DHCP will work though.
You could take it step further and within the facilities wifi network set up a sub net with a different and hidden SSID id dedicated to the mixer.
Also if the wifi network has it available I would look at only using a 5g connection for the mixer. 2.4g can get really congested with other traffic.
no technical restrictions only security issues
but if you are aware of that
there should be no problem
have a look here
and the topic title is misleading… a direct connection would be a WAN cable directly plugged in the QU
and that’s a very bad idea… :frowning:
Thank you!
