Hi all. I’m wanting to send Main L/R to both Matrix 1/2 and 3/4. I have turned everything on what remotely seems likely to send these signals, yet, no signals present.
The info from Google also gives info for that Qu7 that relates to the OLD Qu series, ie 32 as the screens described are nowhere in sight.
Thanks for replying. I know how they work and how to route them, I couldn’t get the levels up. I figured going via the app the morning after I posted this thread. There were the level adjustments and a balance control. Turning up levels via the app and simultaneouslylooking at the display on the desk, up went that control. I didn’t realise that what looked to me like a level meter is the actual adjustment. Incidentally, the desk display is different from the app. Problem solved.
If you mean with it the fader settings of your Main LR Mix in the matrix mixes, the following should also work on your QU:
Select your LR mix with ‘Sel’ and then hold down the ‘CH TO ALL MIX’ button on the left.
Now you should see your matrices in the scribble stripes on the left and can adjust your LR level accordingly with the physical faders.
(Btw.: This ingenious function can also be used for all input and mix channels.)
