Question about number of inputs and DAW integration
Dear QU users,
I’m almost going to order myself a QU32. However, there are one or two things that I’ve not been able to figure out yet and I’m hoping someone might be kind enough to enlighten me :slight_smile:
I’m planning to use the QU 32 to hook up and mix my synths and outboard gear. I plan to connect its AES output to my Metric Halo ULN-2, which will power the monitors and be used to record to my DAW.
I’d like to use the USB connection to route tracks from my DAW to the third fader layer, so I can mix and process DAW tracks on the QU 32, in addition to the signals from the ‘physical’ input channels. (This ought to be possible by creating an aggregate device on the Mac, combining the Metric Halo and QU 32.)
First question: does anybody have a good reason why this configuration might be impossible?
Second question: am I correct in thinking that the QU 32 can process a maximum of 40 tracks (including inputs, DAW and outboard returns)? Or have I misunderstood?
The alternative would be to get a Yamaha 019Vi, but the QU 32 seems so much more user friendly and has more faders. And looks a lot nicer :wink:
John
Hi John My understanding is that there are [analog] 32 inputs with 3 stereo inputs to feed USB B streaming. Digitally coming back into the desk from USB B [streaming] there are 32 lines back in. I could be wrong here but I can only find that many. However if you are working within a Software system on your MAC or PC and can sub mix 'within there' and direct multiple channels you may be able to get them all back in at the same time through the 32 digital channels? Stem cell or master parent as called in Reaper software.
Do you mean back into the custom user layer from MAC/PC? Your Software should be able to do this like a patch bay or matrix?
hope this helps
I’m sure this mixer will do what you want.
There is a new update arriving very shortly which may help you?
The Qu isn’t that flexible regarding input routing. You can stream 32 channels from the DAW back to the Qu, but these are hard-mapped to each of the 32 input faders. There is a selection per channel if it is fed from local analog input, dSnake input or “USB input”. “USB input” can be switched globally between 32 channels coming from the DAW or 16+2 channels from the QuDrive (top usb connector).
Or, to be clear, you can not route any feed from the DAW to any of the stereo inputs.
The Qu32 has a total of 32+3*2 inputs, which is 38, but it can stream 40 (freely assignable) channels to the ME-1 subsystem.
The custom layer is used to re-organize faders, for example to combine some channels along with groups, st-ins and DCAs to be accessible without switching layers. It does not add more input sources.
Not sure why you want to record using the Metric Halo interface. The Qu internally already operates within the digital domain and 32 (assignable) channels are directly recordable into the DAW. The signals won’t improve with an external DAC or AES-to-whatever converter (remember the Qu does not provide a word clock output!).
Thanks dhak and Andreas!
Very helpful info, much appreciated.
Really, what I was wondering is whether I can route tracks from the DAW into the desk and hear the analogue inputs at the same time. So now I understand that it is possible to select the source - DAW or physical input - per individual channel. That’s perfect!
The mic pres and the A/D converters on the Metric Halo are significantly better than anything else I’ve heard so far which is why I prefer to record stuff like vocals and guitars through it - but possibly the Allen & Heath pres and converters will surprise me positively!
Thanks again :slight_smile:
Ok, understood. Sure, specialized ADCs may make a difference. I’d be worried about synchronizing them within the digital domain. If the Metric Halo may slave itself to the incoming AES stream this may be a solution, but then the mac needs to recognize, that both incoming streams (USB from Qu, FireWire from Metric Halo) are properly synchronized.
Otherwise somewhere in the system (maybe AudioCore, maybe your DAW) these will be synchronized by resampling at least one of them.
When you get that sorted please let us know!
I did a little experimenting using Reaper with a firewire GSR24m and QU16 USB B Streaming.
However I gave up as it started getting a little complex and I like to keep things simple especially after not using the gear for a few weeks doing Live sound.
However the MAC is capable of doing what you are asking… on your choice of Software or DAW whether it can handle different sources at the same time?
I do have the Mac running GSR24m with firewire and I did have extra 16 channels being controlled by USB B from a QU16 but then switched to using Ethernet to control those extra channels in the Software or DAW with-in the MAC
Remember you will need to install the A&H DAW app which says to choose either GLD, Zed or QU… and Mackie Control with Audio or TCPIP for Ethernet control only.
I actually installed 2 of those A&H APPs , one into a different folder to try to run 2 of them but gave up on that! I think I lost seeing the ‘wood from the trees’!
You’re probably going to have to beg, borrow, hire, or buy to get a QU ‘just to experiment’ to see what you can and cannot do.
Thanks again chaps, this is all very helpful!
If things don’t work as I had in mind, I’ll just hook the monitors up to the A&H directly, and only use the Metric Halo for recording… That ought to be fairly foolproof :slight_smile:
Thanks again for all the tips!
Received the QU 32 last week and I’m most impressed. Apart from the fact that the EQ and summing sound very, very pleasant and un-digital, it’s a very user-friendly piece of equipment. Considering the audio quality and feature set (things like a genuinely good reverb and ten mix outs, for example) it’s quite a bargain. Also, I’m finding it a LOT more pleasant to mix DAW projects on a ‘real’ board instead of ‘in the box’…
Only ONE last thing I can’t work out - so suggestions most welcome: I want to send all drums to an outboard (Tegeler Audio) compressor and route the compressor output back through a stereo in - but I ONLY want to hear the compressed signal, i.e. not the ‘dry’, uncompressed version. Any ideas???
If you have a QU32 you might want to send outs through there?
You will need to turn off the Top layer feed to you main FOH.
Is that what you are looking for?
Or send out through a Mix and so you can pick up EFX?
Remembering to turn off the dry single to FOH
Good idea, I have an old TL-audio 2U Compressor. I might dig that out :+)
cheers
Hi dhak,
Thanks for replying! Yeah, an outboard analogue compressor on the drum group or vox is awesome :slight_smile: That TL audio is a nice bit of gear :slight_smile:
Your reply is in the right direction I think - my main problem is that I can’t work out how to switch off channels on the main L-R! Probably something really simple, just haven’t found it in the manual :wink:
Sure , youre new to the QU so you need to find it in the Manual.
Because then you will always remember.
Believe it. it was one of the last things I learn’t to do.
How ever.
Its really good to come to grips with this function especially as you have subgroups.
It is right in the middle Page 20 of the latest version PDF
I still struggle with the pre/post green switch. To me the top LED is in reverse mode?..
A bit like some of the old AT radio mics have a RED LED and that means its all good? and when it goes out the battery is flat?
In fact those 2 green push switch’s “signal on/off” to any group mix or group which is selected over on the master section,have got me into trouble in the past where I had to cold boot the system…
Glad to see someone is interfacing analoge outboard gear
anyhow
cheers
Heheheh :slight_smile: True: finding something out by trying and succeeding is the best way to remember it!
Looking at page 20 now - I’m guessing it’s it in the bit about Assign mix routing, using the del/assign keys? (I’m not in the studio now, so must try this tomorrow…) Thanks for pointing it out!
I’ve hooked up a ton of analogue outboard, by the way: spring reverbs, tape delay, tube compressors… Perfectly complements the digital desk!
SONIX time is short… save you time and the info is at the beginning of that page… still look it up though
Sel key (select) – Press to access the Channel Processing. Parameters can
be adjusted using the SuperStrip controls. The touch screen will display the
settings and provide additional controls if either the Processing or Routing screen
is active. The Sel key is also used for:
Assign mix routing – Hold down the ‘Assign’ key and press Sel keys to
assign channels to the mix currently selected in the Master Strip. The Sel
keys light green to show channels assigned to the selected mix.
Assign Pre/Post fade sends – Hold down the ‘Pre Fade’ key and press Sel
keys to toggle channel sends pre or post fader for the mix currently selected
in the Master Strip. The Sel keys light green to show channels set pre-fade.
Cheers dhak!
Got it - the routing was so simple it would never have occurred to me to do it this way :slight_smile: I can now crush all my drums to death with analogue compression - AWESOME! :slight_smile:
Still amazed at how good this console sounds…
Great! Yes, QU sounds really good!
It has a “particular flavour” as does all equipment.
Can you tell me your work flow?
As in drums /vocals out of groups back into Stereo inputs?
This has me thinking…
You can PM me?
I was using QU as sound card (next to my GSR) from PC last few days doing some 2 track mastering with 1K multimedia & soundforge. It made life easy!
cheers
daveNZ
Hey dhak,
Well, I’m using two of the mix outs to send aux signals to external spring reverbs and tape delays, which are routed back in to two stereo tracks.
What I’ve also done, is subtract all my drums from the main output, routed them all to a nice analogue compressor, and feed that back into the third stereo track. So instead of using the ‘normal’ faders for level adjustments of individual drums, I use the sends to the mix out. Works perfectly.
I’ve done the same for lead vocals: remove from main out, send to external analogue eq and compressor, and route back in on a mono channel, using the ‘send’ to the mix output as the level control. Obviously, the louder the output, the harder the compressor is pushed!
This setup works perfectly. The compressors, reverbs and delays in the desk are excellent, but for some things, I prefer analogue!
After only one week, I love this desk!
The ONLY thing that sucks is that I can’t work out a way to route stereo VSTs onto linked mono tracks over USB :slight_smile:
Thos mix outs could of course be set to be post fader, then you wouldn’t have to switch mixes to adjust them - you’d still be operating on the main layer.
Thanks for the suggestion [XAP]Bob!
It would be awesome if I could do everything without switching layers, especially as I’ve routed other tracks like vocals to outboard compressors and stuff.
Unfortunately, my experience with mixer routing is limited to ten years of working ‘in the box’ and some small consoles so I’m not quite sure how your idea would work :slight_smile: Would you mind giving me a little bit more info, so I know more or less how I might set that up?
Cheers, John
