Bonjour, j’envisage de prendre une Qu 5d et je voudrais savoir plusieurs choses avant. Est il possible d’avoir une appli qui permette de faire comme les sq, préparer les consoles sur ordi avec une clée usb. Savoir si il est possible de cumuler un AR 2412 et un autre stage genre DT 16 ou autres… Est il possible avec un Ar 2412 en plus d’avoir 12 Mix Stereo? Merci
Moved this to a more suitable category, since it is not related to AHM.
First, your question translated to English, then I’ll comment, as will others.
“Hello, I’m considering taking a Qu 5d and I’d like to know several things before. Is it possible to have an app that allows you to do like the sq, prepare consoles on computer with a USB key. Find out if it is possible to combine an AR 2412 and another DT 16 or other courses… Is it possible with an Ar 2412 in addition to having 12 Stereo Mix? Thanks”
I myself have the Qu-5 minus Dante. If I am following accurately, yes there’s an app to mix with the Qu-5D, called Qu Mixpad. My Android Samsung S24 ultra phone can run it, as can an iPad. I use both often.
The rest, unfortunately I’m not familiar enough to comment. Sorry.
I also want to try it in English (and not in my native language).
Unfortunately not. You can only set up a QU-5D with the Qu-MixPad app on a PC when both connected, and not offline like with the SQ.
Yes, with a QU-5D you should be able to use an A&H DT16… in addition to an AR2412.
Unfortunately not: A QU-5D has (additional to Main LR) only 6 mono + 6 stereo mixes - or a maximum of 9 stereo mixes.
Thanks for helping him. There’s where I don’t have enough hands on experience with other mixers and stage boxes. Wish I did.
